Old 01-12-2013, 08:25 PM   #26
Andy4639
Old member
Andy4639's Avatar
Talking Re: Any of you guys running a rearsway bar?
Here is a old thread that I did my install a few years ago. I have since taken the bar off only because when I installed the shock relocator kit it was in the way.
http://www.67-72chevytrucks.com/vboa...highlight=iroc
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-12-2013, 10:05 PM   #27
67ctener
67ctener's Avatar
How would I add a sway bar to my rectangular trailing arms from ece? Is it possible?
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 01-12-2013, 10:34 PM   #28
PHAT TONY
PHAT TONY's Avatar
Originally Posted by shawno72 View Post
x2
Me 3!!! My Blazer handles like a watermelon down the ditch!! and it has a front factory bar that seems useless since I lowered it.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 01-13-2013, 01:58 AM   #29
Andy4639
Old member
Andy4639's Avatar
Wink Re: Any of you guys running a rearsway bar?
If I spent the money on those arms I would do the Camaro bar and not have to drill are weld on those arms.
The camaro bar connects to the rear axle and frame nothing would touch the arms.
Old 03-01-2016, 01:28 PM   #30
crakarjax
crakarjax's Avatar
Originally Posted by bonnieclyde100 View Post
here are the pics i promised of my rear sway bar from a late 80s firebird.
I like the looks of this; after some digging I think it's the Addco 414 bar at 1". I'd like to know the dimensions of the bar though and can't find them, anyone have one of these that could measure?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-01-2016, 07:06 PM   #31
Doug's68SS
I did they same as 69CLASSIC, mine is off of a 87 IROC
Doug's68SS is offline   Reply With Quote
Old 03-01-2016, 07:54 PM   #32
casper1969
casper1969's Avatar
Here is my 69 GMC with one from CPP
and handles awesome eliminates body roll and wheel hop
casper1969 is offline   Reply With Quote
Old 03-01-2016, 09:21 PM   #33
muley
muley's Avatar
On my Longhorn, I have leaf springs with overloads. I'm going to haul a 10' slide in camper. It also has air shocks on the rear. Would a sway bar improve the handling with the camper on?
Grandpa 1953 M38A1 Jeep
1989 GMC K2500
1958 Alaskan Camper all original
WORK : A necessary evil that finances
what I really like to do.
muley is offline   Reply With Quote
Old 03-01-2016, 10:57 PM   #34
72MARIO
72MARIO's Avatar
Yes it would.
I used the same bar as above for leaf spring rear from addco. The truck is used for my roofing business. Its like driving a lowered truck now handles great thru the corners loaded or empty
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-01-2016, 11:41 PM   #35
Possmguts
Possmguts's Avatar
Using the No Limit above frame bar...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-01-2016, 11:57 PM   #36
muley
muley's Avatar
Originally Posted by 72MARIO View Post
Yes it would.
Thanks. I have a front stabilizer, and kinda thought one on the back wouldn't hurt. I've hauled a lot of tractors on trucks, but never a camper in a pickup. Wasn't sure how much sway there would be.
1989 GMC K2500
Old 03-02-2016, 01:05 PM   #37
crakarjax
crakarjax's Avatar
Looks like you had to trim some mounts to get that bar installed. Why not mount it to the bottom of the frame rails?
Old 03-02-2016, 06:57 PM   #38
Possmguts
Possmguts's Avatar
Nope.. nothing is or was trimmed... drilled the holes for the 2 mounts was all. Its mounted per instructions and the way its designed to be mounted. If it was mounted under the frame rails it would interfere with exhaust pipes and would have have the right angle anyway.
Old 03-03-2016, 12:53 AM   #39
crakarjax
crakarjax's Avatar
Good point re: exhaust, I think that the exhaust should be routable above the bar in between the frame rails though, and flipping the bar would probably correct the angle enough... and if not the links could be resized to do so. I'm going to have to take some measurements but maybe I can find a bar that would be suitable for bottom mount...
Old 03-03-2016, 01:06 AM   #40
'68 Newtricks
'68 Newtricks's Avatar
it's all about mounting to the axle itself
if that means mounting towards the rear, between frame rails, or above rails..... it's all good as long as part of it is attached to the axle.
Mine however, is attached to the trailing arms. I'll probably change that when it comes up on the "to-do" list.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 03-03-2016, 01:11 AM   #41
crakarjax
crakarjax's Avatar
No doubt! I've got a plan that will put the end links right next to the axles, which is good enough for me
Old 03-03-2016, 08:11 AM   #42
Possmguts
Possmguts's Avatar
Ok, but keep in mind that No Limit has a road course truck they have build using this bar. They tried several ways of doing it and this setup works the best...
Old 03-03-2016, 09:49 AM   #43
Ekliptix
Ekliptix's Avatar
I have the ECE front sway bar installed (awesome). I have the CPP rear sway bar but have not installed it yet. Will report any differences in the driving experience.
Ekliptix is offline   Reply With Quote
Old 03-03-2016, 12:46 PM   #44
crakarjax
crakarjax's Avatar
Is that hellboy? If so they use a splined torsion bar, not the rear bar that they sell. Maybe that should tell us something...
Old 03-03-2016, 06:48 PM   #45
Lattimer
Lattimer's Avatar
I have a Camaro Hotchkis bar mounted to the trailing arms. Seems to work very nice for me. I think mounting it to the arms keep sit from being too much.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-04-2016, 05:36 PM   #46
Possmguts
Possmguts's Avatar
Well then.. I stand to be corrected... I thought I read somewhere they used it.. maybe it was on another truck. But I guess since you're so hell bent on being against it and the way its mounted, you'll come up with something that works for you...
Old 03-05-2016, 03:45 AM   #47
crakarjax
crakarjax's Avatar
No way! I only seek the truth...
Thread Tools
Display Modes
