Old 09-09-2012, 02:36 PM   #26
frog210
Re: How do yall set yalls body lines?
okay just waiting for my package to come in the mail lol
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 09-09-2012, 07:55 PM   #27
Keith Seymore
Keith Seymore's Avatar
Originally Posted by cmyc5575 View Post
well it looks like your passenger side is below the bed line where as you driver side is above the bed line. lets say that the passenger side bushing is rotted away which would explain that cab being lower than the bed line on that side, what would cause the driver side to be above the bed line, unless there are bushings that are under the bed connected to the frame that are also rotted that caused this. but i thought they did not set these beds on bushings all it is, is metal on metal or am i wrong? I am confused! if i thought correctly it looks like that frame was twisted. Unless in this pic are you on even ground or on a hill which would also explain that your frame is twisting to one side making it look like that driver side is higher than the passenger side.
The bed sits directly on the frame (metal on metal).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-11-2012, 06:00 PM   #28
cmyc5575
Thansk for the clarificaton seymore! Why didnt they make this with bushings under the bed becaue i thought it would only make sense that the bushing would help take vibration out of the bed or partial frame?
cmyc5575 is offline   Reply With Quote
Old 09-11-2012, 08:54 PM   #29
Keith Seymore
Because you don't feel or hear any vibrations that come from the bed (...unless you are riding in the bed).
The only vibrations that you feel are in the cab and front end sheet metal - hence the cab and radiator support are mounted on rubber isolators.
K
1979-1986
1986 - 2019
Old 09-12-2012, 05:27 PM   #30
cmyc5575
K
Ok Thanks for the info
Old 09-13-2012, 10:27 AM   #31
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Question Re: How do yall set yalls body lines?
Are the new'er trucks built the same way ?
johnnyclack is offline   Reply With Quote
Old 09-13-2012, 12:17 PM   #32
snm95ls
Yes.
snm95ls is offline   Reply With Quote
Old 09-13-2012, 12:31 PM   #33
johnnyclack
Interresting. Thanks
Make sence when you take into considerationn Load Compression if the beds were shimmed this would possibly lead to a loose mount (spelled rattle) later on
Old 09-13-2012, 01:01 PM   #34
frog210
My bushing should come in today can't wait
Gonna have to crawl under the dodge later to check out hoe its done on the dodge
San Antonio, TEXAS
-Frog
Old 09-19-2012, 03:21 PM   #35
frog210
Well i finally had a chance to do the bushings
and its a bi*** to do without the right tools but it can be done lol
I for some reason couldnt find none of our bottle jacks, so i had to use 2 scissor jacks on concrete bricks, this made it fun trying to get in and out of under the truck fun
also if you have more free time you can take of the tank and it would make it easier i didnt
put one jack my the front passenger cab bushing and another one in the middle back(my frame, tank, exhaust was in they way so i did with what i had
it was a slow process of turning on scissor jack and then the other
These things were toast
you have to lift like a good 4-5 inches to get the bushings back in
you could still see the part numbers on these old rubbers lol not bad for 38 year olds
did lift my passenger side like 1/2-3/4 of a inch my passenger side body line almost match now
drivers side is a little higher, i think the po put a few 6 extra washer to try and fix it, will take a look in a bit
San Antonio, TEXAS
-Frog
Old 09-19-2012, 04:25 PM   #36
johnnyclack
the "Shade Tree Mechanics Oath"
We SHALL Improvise, Adapt , Overcome
Old 09-19-2012, 05:31 PM   #37
cmyc5575
OOOOOOOOOOOOO i want to see some pics of the finished product on that one side.
Old 09-20-2012, 09:20 PM   #38
frog210
These are the only pics i got
passenger side matches
driver side dosnt didnt have a chance to work on it
but it looks like the PO but like 6 extra washers???? lol
San Antonio, TEXAS
-Frog
Old 09-20-2012, 09:21 PM   #39
cmyc5575
So, do you still have to do the driver side?
Old 09-20-2012, 09:23 PM   #40
cmyc5575
It still looks like the driver side is higher than the bed line. Could they have possibly over shimmed the driver side mount?
Old 09-20-2012, 09:25 PM   #41
frog210
Yea the PO put like a extra 6 washers wtf lol
should get that taken care off,
but the passenger side is straight and flush
San Antonio, TEXAS
-Frog
Old 09-20-2012, 09:27 PM   #42
cmyc5575
thats so funny. Yeah I noticed the passenger side is amazing now that new hardware is in. Great job my friend.
Old 09-20-2012, 09:34 PM   #43
frog210
yea i think once i remove those washers it should line up
and should flush the passenger side a little more
if you see in the third pic it leans a little bit
but i think if i remove like 4-6 of them it should level it out
San Antonio, TEXAS
-Frog
Old 09-20-2012, 09:39 PM   #44
cmyc5575
Well you know what that means right? MORE PICS!!!
Thread Tools
Display Modes
