10-25-2012, 10:46 PM | #26 |
Old member
Re: Camper Special or Custom Camper?
Just another side not. Using house wire nuts is a really bad thing. They aren't made for vibration getting oil, grease and wet like under a hood.
Best thing is trace all the wires one at a time and the long ones try to reroute them to shorten them up. I beat some of them aren't even hooked up.
03-30-2013, 07:02 PM | #27 |
Yes they are the same spacing and interchangeable.
69 Chev C20 396 T400 Dana 60 3.54 A/C Daily Driver - Stolen 67 Chevy C20 CST |
11-19-2013, 08:05 PM | #28 |
I always thought my 72 was a custom camper but it doesn't have the emblems, just camper wiring and extra fuel tanks. Does anyone know what was included in the custom camper option?
11-19-2013, 10:08 PM | #29 |
The emblems use same pin location- they are enter changeable
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-19-2013, 10:32 PM | #30 | |
For the 67-72 production years there was not a specific package like later trucks. All that was needed was to meet specific equipment requirements, these varied with the truck models, and the emblems could be ordered. Camper wiring and aux tanks might indicate it was used a camper carrier but have no bearing on if a truck was or was not a "Custom Camper". A SPID or a build sheet are going to be the only way to verify a factory Z81 truck.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 11-20-2013 at 09:39 AM. |
11-19-2013, 11:45 PM | #31 | |
Hey Tim... welcome back!!! Jim |
11-20-2013, 09:34 AM | #32 |
Welcome back,Tim. I might have missed it but,although GM did call them Custom Camper in 66-72,some SPIDs are printed with Special Camper(1st pic) and others with Camper Nameplate. All '72s I've seen have Custom Camper Equip typed on the SPID. Here's one I've pondered. Can anyone offer anything on these emblems (2nd pic)? They say the GMC version of the Longhorn was called Custom Camper,although none had any type of badge. This always confused me,since any 2500-3500 could have the Custom Camper option. So,if you had a 133" Wideside with Custom Camper option you had a Custom Camper Custom Camper and your buddy's 127" is a Custom Camper. Let's not get into adding a trim level in (1969 Super Custom Custom Camper Custom Camper). < Please leave that one original or we'd have a custom 1969 Super Cus... So,what did my 3500 Custom Camper badges come on? I've never seen any GMCs with Custom Camper fender badges.
11-20-2013, 10:16 AM | #33 |
Tim, Its true the verbage on the SPID is often a little off from the sales name of an option. It still comes back to what I have said all along the RPO number is what you need to concentrate on. There was too much variation between plants and years much less running changes to give an absolute on a SPID descriptions.
As to your badge there, that is a very interesting find. Not sure what they came off of or year. They may have been intended for a Custom or Super Custom with Z81. Possibly a deconfliction measure like Chevy did in 72 to have both trim level and Custom Camper emblems. Any numbers on the backside?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
11-21-2013, 08:13 AM | #34 |
Yep,all about the code. It's fairly common to see Sierra Grande on the SPID,yet are Z84 Sierras. I found an all original '71 Cheyenne Super a couple months ago with Z84 listed as the code. So,sometimes it's the code that's incorrect. This was a true Cheyenne Super with chrome tailgate handle and w/g dash pieces.
I'll get back with the numbers. I had run this past Longhorn Man and we came up blank. These will go on my '72 once I put the HO52/Dana 60 under it. Once I ever restored it I'll probably go with these other badges,because they are so "mint",and put the door scripts back on
11-30-2013, 05:12 PM | #35 |
Nice badge there Tim, I'm guessing it came off of a base 6cyl truck.
Again there are a lot of variations even with the RPO codes and useage. The 71 Cheyenne Supers are often found with both Z84 and YE9. IIRC one early build Fremont truck had Z84 on the SPID but both Z84 and YE9 on the build sheet. St Louis has always seemed to have more variation than most plants when it came to SPIDs.
Thread Tools | |
Display Modes | |
