Old 11-07-2012, 11:54 PM   #26
i8tokyo
Re: SquareBore to Spreadbore Adaptor Plate! (Is it Necessary?)
I've had the adapters and they work ok. I never noticed a crack, but it did develop a small vacuum leak on the manifold side after awhile. I got a deal on an intake and never looked back. One thing I can highly recommend is a heat insulator gasket with an Edelbrock carb. You'll be happy you did in the summer months.
BTW, the Edelbrock intake you would want would be pn 2161. I got mine off ebay for $50... It's for the peanut ports that I assume you have.
Originally Posted by savatreatabvr View Post
Yes it's stock and yes I know I need the #2696 but here's what I was told about the 2696! Lopers, (a High Performance Shop here in Phx) said the Edelbrock 2696 Squarebore to Spreadbore adapters have a tendency to crack and cause minor to severe vacuum leaks! I didn't know if I should believe him or punch him, lol, so I walked away empty handed! Ya know a big block aluminum squarebore intake manifold doesn't sound like a bad idea now, Lol!
1982 C-20, 454, TH-400, PS, A/C, 71,000 miles
1978 C-20, 350, TH-400, PS, Non-A/C, 112,000 miles
If it ain't broke, there is still probably room for improvement.
Speed costs money, how fast do you want to go?
i8tokyo is offline   Reply With Quote
Old 11-08-2012, 06:16 AM   #27
wraprail
wraprail's Avatar
Originally Posted by INSIDIOUS '86 View Post
I had a carb spacer test saved on my computer but the computer is no longer... And I can't find the article again. But take a look and tell me how bending the air almost 80* right as it exits the carb isn't going to be detrimental?
This is an Edelbrock adapter pictured. I have this adapter on my stock 350 with an Eledbrock carb and it works fine. I did however smooth the casting with a file and some 80 grit as it was a little rough (made in china)
A square bore will not bolt on a Q-Jet intake. You must use adapter
wraprail is offline   Reply With Quote
Thread Tools
Display Modes
