02-20-2015, 08:21 AM | #26 |
Re: 40 Gal suburban Gas Tank into 71 4x4 truck install.
87-91 Suburbans were fuel injected. That's the tank I'm using.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
02-20-2015, 08:38 AM | #27 | |
That may not generate enough fuel line pressure for more modern injection systems (EFI, TPI, multiport, etc). I recommend you double check the pressures just to be sure. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-20-2015 at 08:45 AM. |
02-20-2015, 09:07 PM | #28 | |
Stock TBI pressure for the 87-92's was between 12-15psi. I would like to find a drop in pump that feeds 60 psi for my Edelbrock Pro Flow system that will drop into these suburban 40 gallon tanks. I'll start another thread to keep this one from getting too mudded up. Thanks gang. Steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
02-20-2015, 09:17 PM | #29 |
Just out of curiosity and ignorance what's the benefit of in tank bs inline?
I just had the pleasure of swapping the one out in my 93 and as I look to install tbi on my 72 I really question if I want to have it in the tank |
02-20-2015, 10:30 PM | #30 | |
1) fuel keeps the in-tank pump cool making for longer life. 2) these pumps work better as a pusher rather than a puller. i know there's debate depending on the pump here. 3) eliminates loss of prime of the pump. im sure others will chime in.
02-20-2015, 10:44 PM | #31 |
Keith, I'm running a ACDelco EP381 not a TBI pump
07-20-2015, 08:29 PM | #32 |
Could you give dimensions of the tank? want to put on one my 71' burb.
07-20-2015, 08:44 PM | #33 |
40 gallons id need another job just to fill it . nice work though
07-20-2015, 10:05 PM | #34 | |
Beware the fuel filler is, not only on the wrong side, it's in the wrong place. So be prepared to move it. Also the neck is 1.75" and your Suburban filler is 1.5"
Thread Tools | |
Display Modes | |
