12-09-2012, 03:52 PM | #1 | |
Re: Which engine to get?
X-2 !!!! I just told a board member the same thing a few days ago..
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
12-09-2012, 03:41 PM | #2 |
the problem with the th350 for mileage is it does not have a lockup converter, the problem with the 6.0 for mileage is they dont get better than a old school small block. i would go with a 5.3 and if you arent racing a 4l60e, proper tune decent headers and intake and your making big block hp with less torque but the weight is WAAAY down. you can pull mileage from a big block with a 4l80 and a good carb if its a healthy big block, the problem is not OD if you are driving up hill all the time its the lockup converter if they dont lock up its like your riding the clutch all the time.
1969 C2500 350/np435 1983 malibu wagon vortec 350/700r4 Gillis |
12-09-2012, 03:55 PM | #3 |
I should have added that the "new" 4.8L from 07+ has almost as much power and torque as the 99-07 classic 5.3L but with no AFM, a "new" 4.8L from 07+ may be an affordable option as well, but I'm not sure, because nobody ever talks about them, everyone wants the 5.3L or 6.0L
I also don't mean to scare people away from new GM trucks. The tech I talked to said a lot of the problems are from people using the OLM to change the oil, which can be in excess of 7K+ miles. The lifters have a tiny oil orifice and can be easily plugged. He said on engines that get the oil changed with good synthetic from 3-5K miles there doesn't seem to be many issues, and you can turn off the AFM with a tune, but as far as these old trucks are concrened for engine swaps... just stay away from them.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-09-2012, 04:43 PM | #4 |
A day late and $1 short...
When you have the tune redone, they will likely remove any "torque management" that robs power at the rear wheels. You will be very surprised with the power, I was! My 5.3l/4L60E has a ton of go!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
12-10-2012, 01:44 AM | #5 |
Have you considered a SB swap? I realize the ls motors have better mileage potential and would definitely be worth it in the long run but the initial cost and downtime involved would be a factor for me. I would be curious about the cost of a good running 96-2000 vortec 350 from a junkyard. Throw a carbed intake on and your off and runnin' complete with serpentine accessory drive. The 4l60 as you may well know requires a electronic speedo or you can always drive by gps.
12-10-2012, 02:04 PM | #6 |
Great info guys!! Y'all are really helping me out!
67chevyredneck, what is the "AFM" that your referring to? Averagejoe, I thought about doing the sbc swap, but at the end of the day it seems that the ls would be a better swap. I'm not terribly concerned about the down time since I have another vehicle, but I don't want to take months either. I figure if I get everything ready before hand I should be able to knock it out in a couple of days. I also thought that the cable x box would convert the signal, am I wrong? Looks like I need to find a better deal on the 5.3 combo that what I've been quoted. Thanks again guys!! Posted via Mobile Device
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
12-10-2012, 03:58 PM | #7 |
Are you going to be doing any towing/hauling with the truck?
12-11-2012, 01:25 AM | #8 | |
My 2-cents!...plus several thousand $'s worth of experience!!! Re: 2nd bold quote above: In our area, the 5.3 gives such little trouble, the salvage yards are "backing up" with a supply of them. As such, you can buy one with miles(150K+/-) for approx. $550-750. I'll admit it's hard to find one with low mileage, but even then, it's waaaaay cheaper than $2500, including the 4L60E. Another thing: Another poster mentioned the 4.8. It has just 10 less hp than the 5.3. One of the Hot Rod mags recently did an article where they bought one from junkyard, approx 178K miles(iirc), did not rebuild it, but experimented/dynoed with cams, carbs, and finally blowers. Said they were gonna keep increasing pressure and checking outputs UNTIL IT BLEW--just to see how much hp they could get. THEY ULTIMATELY GOT 1015 (MAYBE 1025) HP--BUT IT NEVER BLEW!!! Funny thing: they thought all along that they were working with a 5.3--they look so much alike. Only found it to be a 4.8 after they finished testing it and tore into it to see if they could find any abnormal internal wear!!! I'd not shy away, esp. if I was gonna heat it up a tad--on whatever I bought. sam |
12-11-2012, 04:13 AM | #9 |
My$.02
Best mileage? 5.3. Nothing wrong with AFM, IMHO, if it's maintained. OD a must, 4l60. I've had both (All early Gen III's rattled when cold due to harmless piston slap) and prefer the 6.0 for the 4 inch bore. Much easier to make loads of power with.... but this is not your goal. Good luck....... |
12-10-2012, 04:26 PM | #10 |
AFM is Active Fuel Management. 4 of the cylinders "shut down" under light load, essentially turning the V8 into a V4 motor to improve fuel economy. It is used on all 2007+ 5.3L motors. I think it was used before 2007, but not widespread, and I THINK only on the all alumnimum 5.3L, again, not sure on pre 2007 5.3L. OLM is Oil Life Monitor.
12-11-2012, 12:58 AM | #11 |
Not towing too often. Mainly daily family duties.
12-11-2012, 09:05 AM | #12 |
Well after looking through here I think I've decided to go with a 5.3 to replace my 454. Good thing is I already have a beefed up 700r4 in my truck.
Erik 1969 Chevy K20 6.0L/4L80E/NP205 1971 Chevy C30 Cheyenne Longhorn 454/TH400 1979 Chevy K30 dually currently in pieces |
12-11-2012, 11:08 AM | #13 |
I have a flywheel and adapter for the 5.3L/700R4 combo for sale if you need one.
01-04-2013, 01:56 AM | #14 |
hey guys! Thanks for all of the comments so far. I've been a little busy with the holidays and such so I haven't really been on here much. So i found another 5.3/4l60e combo for sale. It comes from an '05 yukon with 33k miles. The tranny was rebuilt and has a 4l80 convertor (seller said that was recommended by the gm tech that rebuilt the tranny for him). It comes with everything but the pedal. The seller wants 2000. does that seem like a good deal?
Also, I thought I understood that the truck intakes have a return fuel line with regulator built in. If that is the case, my '72 already has a return line, so do I still need the corvette filter/regulator? I am now understanding that the Trailblazer SS manifolds are a good replacement with no need to trim anything. . Alan groves will provide the sanden ac bracket relocation so I can keep my vintage air. I can move my th400 tranny crossmember and redrill it. I think using the dirty dingo mounts would be best for positioning, but I think I need to use the 73+ frame stands. Will these mount easily to the bigger 3/4 ton frame? Where can I get the power steering adapters to connect the 5.3 power steering box to my '72 gear box? Also, whats the verdict on electric fans vs using the stock clutch fan? benefits? Sorry for all of the questions. But I've been given the green light to do it,but will only be able to have the burb down for about a week. I need to have everything ready to go when I decide to pull the trigger. Thanks for all of your help guys!! Shawn
01-04-2013, 05:22 PM | #15 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-04-2013, 11:29 PM | #16 | |
I thought the frames were similar, but I was t sure if the 3/4 ton frame rails were taller or not. Thanks for the verification. Posted via Mobile Device
02-03-2013, 02:32 PM | #17 |
Any updates on this?
01-04-2013, 02:24 AM | #18 |
the boat guy
No need for new power steering lines. Swap the fitting from the old pump into the new pump.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-04-2013, 03:07 PM | #19 |
Awesome!! That's great info. Any more feedback on my other questions?
Posted via Mobile Device Posted via Mobile Device
02-03-2013, 05:47 PM | #20 |
Not yet. I'm kind if paralyzed with indecision. I really want to do the duramax swap, but it will eat up most if not all of my monetary resources. That's IF nothing drastic occurs or goes wrong. I'm also waiting on my neighbor to letme know something on a 6.0 with 22k he had in his shop. Everything tells me the smart money is on a 5.3/6.0 swap, but the duramax would be just too darn cool and get better gas mileage. I just don't see how they differ much installation wise except for the initial engine cost/outlay. They both need motor stands (although the ls style motor ones are easier to come by commercially), they both need the wiring harness configured, they both need driveshaft mods, the duramax may be able to use the original radiator and intercooler, the duramax will need a hydrobooster, which wouldn't be a bad upgrade anyway). The ls swap will require a fuel pump which the duramax won't. The duramax will need the tranny tunnel raised though. But luckily mine unbolts so I should be able to add some height without too much drama. I just don't know.
02-03-2013, 11:02 PM | #21 | |
02-03-2013, 11:56 PM | #22 | |
02-03-2013, 10:03 PM | #23 |
Vintage 4x4s
The Dmax is heavy so you'd want to beef up your front end, factor that into the cost. And consider the trans you'd need behind it and how to control that trans.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
02-03-2013, 11:52 PM | #24 | ||
02-03-2013, 10:46 PM | #25 |
Just got my 402 back from the engine builder and it made 496/479 with 16" of vacuum streetable 226/234 hyd roller cam. I think it will be fun to drive. I dynoed it with a crappy 870 street avenger carb that had trouble @4200 rpm with the secondaries and the top end a/f ratio was a little fat @11.8/1 It will be better with my fast injection.
NAME: TRAVIS TRUCK: BRUISER 71 C/10 SWB 3.5/5" drop 4.11 GEARS. F.A.S.T. BBC 408 496hp/479ft/lb JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530 |
Thread Tools | |
Display Modes | |
