Old 12-27-2012, 03:46 PM   #26
barraza
Re: GMC "Leaf Springs" Why ?
There was no love lost between Chevy and GMC at the time. They considered them selves in competition just as much as with Ford or Chrysler. It was a different philosophy. Coils do definitely ride better, due to less friction in the system. A coil also locates the axle better than leafs. BUT , leafs are much easier to engineer a variable load rate spring. A leaf can theoretically have a softer spring rate at light loads and a much heavier rate at heavy loads, that is why most leaf systems have many leaves. Most trucks still use leaves for this exact reason.
Leaves also have a natural anti sway effect due to the twist the spring must have as the truck leans. With a coil, a sway bar must be used to have the same effect.
And the above answer about wood beds is correct. A long time ago, small farmers typically hauled livestock to market in the bed of their truck. Much better footing on wood.
barraza is offline   Reply With Quote
Old 12-27-2012, 08:31 PM   #27
68gmsee
Active Member
68gmsee's Avatar
Very true. Also we tend to forget that the trucks were mostly for work not for cruising like a lot of them are today. My dads metal bed truck had tons of dents from hauling wood and bricks, etc. and a neighbor with a wooden bed truck that also did similar hauling the wood was relatively unaffected.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Thread Tools
Display Modes
