Old 06-17-2003, 06:49 AM   #26
dwaite72lnghrn
Quick note besure to check the ground wires! Electronics don't work well with bad grounds. Just moving parts or the distributor could get a good bond that time oxidizes or oil stops. Run a wire to the hold down clamp to a good ground.just my 2cents
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-17-2003, 09:32 AM   #27
Yellow Cheyenne
Heat sink grease is not to insulate the module from the distributor. It is designed to help conduct the heat from the module to the distributor. Without the grease or any form of heat sink, the module would burn up in a short amount of time.
Randy
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
Old 06-17-2003, 04:19 PM   #28
vfrdude
vfrdude's Avatar
The purpose of the dielectric grease is to dissipate heat from the module to the distributor housing... without the grease the ignition module will fry....
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
Old 06-17-2003, 04:29 PM   #29
ddsmith
Glowing since 1978
ddsmith's Avatar
Yellow Cheyenne and vfrdude thanks for the clarification. I knew it was needed just had a misunderstanding of purpose. That is why this board is great. I think I actually knew the right answer at one time but that was several books ago. You know my bookself is full. If I add a new book(something I've learned) one of my old books(something I use to know) falls off the shelf. To bad I can't add a bigger hard drive in my head.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 06-20-2003, 04:30 PM   #30
jimfulco
One good thing about points, they won't make you walk without telling you about it first.
jimfulco is offline   Reply With Quote
Old 06-22-2003, 12:48 AM   #31
Phillip Johnson
Phillip Johnson's Avatar
Got a NEW HEI this weekend.. Im happy now
Phillip Johnson is offline   Reply With Quote
Old 06-22-2003, 10:59 AM   #32
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Could someone give an expanded explaination of the resistor wire. Wat does it do?
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-22-2003, 11:16 AM   #33
Project1970
14.1 @ 96MPH
Project1970's Avatar
It drops the 12V down to I believe 7V for the old points coil. Since the HEI needs a solid 12V source, it should be disconnected and/or removed.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 06-22-2003, 12:02 PM   #34
dwaite72lnghrn
The resistor wire does drop the voltage but I believe the main object is to set the current(amps) level running through the coil. If you put a staight wire from the battery to the coil you would burn out the coil quickly and the points would burn much faster. The old mopar and ford used a ballast resistor right on the coil, A big square ceramic type wire wound resistor.
2009 HHR aqua blue
Dave & Jeanne
Old 06-23-2003, 05:35 AM   #35
GMC Jim
GMC Jim's Avatar
i believe the resistor wire should drop the voltage to 9.6 volts.......Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Thread Tools
Display Modes
