Old 03-19-2013, 02:49 PM   #26
JointTech
JointTech's Avatar
Re: Rear differential oil
mine didnt have a drain hole. Had to just crack the cover and let it drain.
The fill hole is the square bolt on the back. I had to use the extension hose/straw thing to get it filled.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 03-19-2013, 02:49 PM   #27
Lattimer
Lattimer's Avatar
Originally Posted by Mister-B View Post
Guys I need some quick help. I'm ready to do this, but can't locate the drain or fill plugs. I may have located one that's a square bolt on the back side, but I'm not sure about the fill hole?
Some don't have a drain, so you have to pull the back cover off to drain it.
If the square plug in the back is about halfway up, that is the fill.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-19-2013, 02:50 PM   #28
weaintscared
weaintscared's Avatar
I use Royal Purple,,,it's the good stuff..
my build http://67-72chevytrucks.com/vboard/s...d.php?t=468622
weaintscared is offline   Reply With Quote
Old 03-19-2013, 03:10 PM   #29
Mister-B
Thanks guys!
Mister-B is offline   Reply With Quote
Old 03-19-2013, 04:55 PM   #30
Mister-B
Got it all done. I just backed out the bolts a bit and then gently used a flathead screw driver at the bottom to open it up just enough for the fluid to drain, without hurting the gasket.
Boy, this 3/4 ton has one big rear end. Felt like I was working on Jennifer Lopez back there lmao. It took all but one quart of that gallon jug. Thanks for the tip for the pump, Gary. I got one at Autozone, and it made of a very clean job
Old 03-20-2013, 09:51 AM   #31
Mister-B
This video of a truck driving with a clear diff cover is what made me want to change my fluid ASAP. Glad I did. That old fluid was thick and nasty
http://m.youtube.com/watch?feature=y...ure%3Dyoutu.be
Old 01-13-2016, 07:55 PM   #32
cadillacart
1972 C/20
cadillacart's Avatar
My 1972 C/20 has a Dana 60 rear with posi in it and 3.75 quartz filled it.
This unit has floating rear axle, which require you to jack up a side to let some oil run down the tubes and lubricate the wheel bearings.
Hopefully this helps... I thought this info would be easy to find, but I guess not all Dana 60s are the same...
My Gallery
1972 C/20 402
Gramp's Truck
cadillacart is offline   Reply With Quote
Old 01-14-2016, 12:37 AM   #33
cadillacart
1972 C/20
^^^ sorry to confuse...
2.75 was the actual amount of quartz needed.
My Gallery
1972 C/20 402
Gramp's Truck
Old 01-14-2016, 01:33 PM   #34
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Rear differential oil
Thanks everyone. That is one large rear end to need that much fluid
I can only imagine how long it may have gone between being changed. A guy on the forum posted a link to a video of a truck like ours with a clear diff cover. It's amazing how much that fluid gets stirred around. It made me want to change my fluid
That would be me!
I just took it off and chunked it in the trash too! The thing kept leaking. It had cracked and was dripping.
I put almost 2 bottles in it before it started coming out the hole.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Thread Tools
Display Modes
