#26 |
A day late and $1 short...
Re: 1968 4/6 drop questions
I am running 22x9s with 5.5" bs on the rear and no clearance problems.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#27 |
#28 |
I verified that the rims are 10" wide in the back. I can't seem to find where the backspace is etched on the back of the spokes but will keep looking. I have maybe half an inch of clearance between the tire and bed on each side. The outer fender clearance is a bit less. Lowering the rear has moved the rear tire back over an inch so it does not sit centered in the wheel well. Any clearance issues are now going to be at the back fender lip now. So far I have no indication of any rub or bump stop issues. This tire/wheel combination pretty much fills up the rear fender well space on a step side.. Hope this info helps.
Posted via Mobile Device |
#29 |
Here is a pic of my bed clearance... Not a whole lot of space.
#30 |
Thanks for the info and pictures, mine are about that close right now also but it has cut springs, thinking about going with the same kit you went with
#31 | |
As far as the wheels go, you will likely have to pull a wheel and measure it. Many people stick with an 8.5" or 9" wide wheel and a 265 width on a step side to ensure adequate clearance. With a 69 and earlier rear end and depending on wheel width a 5" to 5.25" bs works well and with the longer 70 and up rear end a 5.5" bs works well.
#32 |
I have 4.5" front and 6" rear with ECE components.
Thread Tools | |
Display Modes | |
