Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 05-14-2013, 10:56 PM   #26
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1971 GMC Jimmy drivetrain and misc parts
Do you have the throttle cable assembly that goes from the accelerator pedal to the carb. Do the Jimmy's have the square mounting hole in the firewall like the pickups do? All I have are the longer ones and I need a short one.
If so, price shipped to zip 50171.
Thanks.
LockDoc
Leon
Old 05-15-2013, 01:07 AM   #27
DeadheadNM
Carpe manana
DeadheadNM's Avatar
FYI- that metal upper rad tube may still be useful to someone doing a 700r4 install into a 4wd (as I did) depending on the size of the hole. The ends need to be cut slightly to accommodate the new geometry that comes from moving the engine forward.
Old 05-17-2013, 08:18 AM   #28
ccsrcr
D.Pass: I'm not the original owner, so I cant say for sure if they are original or not.
Deadhead: Ok, I think I have another upper tube from the 72 blazer that im parting out, but I cant locate it right now, if its good, I will let you know.
Willow: I think I have them, but have a lot of stuff packed in the back of the jimmy now, so will have to check once I clear some parts out.
Lockdoc: The cable on the Jimmy is really long, so probably wont help you.
ccsrcr is offline   Reply With Quote
Old 05-20-2013, 12:47 AM   #29
rawraw67
rawraw67's Avatar
any steel rims?
rawraw67 is offline   Reply With Quote
Old 05-23-2013, 11:15 AM   #30
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by DeadheadNM View Post
Also interested in the oil dipstick/tranny fluid filler....thanks
Just checking back in....thanks.
Old 05-24-2013, 09:31 AM   #31
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Do you have the transfer case shifter? If so how much?
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 06-10-2013, 04:03 PM   #32
72K5er
Is the rear axle still available? If so, what is the gear ratio and how much do you want for it? Thanks
72K5er is offline   Reply With Quote
Old 06-11-2013, 10:09 PM   #33
cudaman
Did you ever get a chance to check on the rear seat belts?
cudaman is offline   Reply With Quote
Thread Tools
Display Modes
