Old 06-27-2013, 10:04 AM   #26
McCoyAZ
McCoyAZ's Avatar
Re: Axels only or whole rear end swap?
One last question if I may:
Assuming I do keep the axels I have and convert them to 5 lug.
The brake drum of choice should be which one? I most likely will just buy new ones to avoid having them turned, Just need to know which year truck drum is the best choice for the stock axel?
McCoyAZ is offline   Reply With Quote
Old 06-27-2013, 03:07 PM   #27
lasher78
lasher78's Avatar
heres my 12bolt. appears to maybe have leak, has wettness around left outer edge.
live like you are dying
lasher78 is offline   Reply With Quote
Old 06-27-2013, 03:33 PM   #28
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I think there are two sizes of brake drums, Please correct me if I am wrong.
I put 71/72 drums on mine when I had the Axles converted to 5 lug. Also, the brake check needs to be turned also ( axle center part, I think it should be 3.0866" or 78.3mm)
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-27-2013, 03:49 PM   #29
McCoyAZ
McCoyAZ's Avatar
I think there are 2 sizes 2 inch and 2 1/2 inch....but I reserve the right to be wrong. Standard 1/2 ton truck is the smaller of the two I believe.
Old 06-27-2013, 04:33 PM   #30
65Gregg
65Gregg's Avatar
Originally Posted by lasher78 View Post
my origanal is a 12bolt with 3:73 gears not posi. i am wanting to have 3:08 gears for better gas milage as this truck is going to be everyday driver. so i just figured it was cheaper to find newer rear with those gears and do the welding for springs vs. buying news axles and gears for mine?
I you decide to switch your trans to an OD, I would reconsider which ratio you use. I have 3.73 with 28.5 tall tires on the rear and a 700r trans and don't think I'd go to anything else for fear of bogging with a 3.08. Just my$0.02 worth.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 06-27-2013, 05:47 PM   #31
lasher78
lasher78's Avatar
i would like to switch to 700r4 but cant find one for a reasonible price, so right now stuck with the th350 but i may just keep rearend and see how much to change out axles to 5 lug with the hope of finding700r4 soon after.
Old 06-28-2013, 12:08 AM   #32
Captainfab
60-66 Nut
The same 11" x 2", 5 x 5 drums were used from '71 up thru the mid 70's. The 11" x 2.75" drums and brakes were an upgrade option. You would have to change the backing plates also to upgrade the brakes.
Yes you do also have to have the hub register turned down when you change the axles from 6 x 5.5" wheel stud pattern to the 5 x 5". The 6 x 5.5 hub register is aprox 3.5" and the 5 x 5 hub register is aprox 3.062".
Old 06-28-2013, 12:14 AM   #33
Captainfab
60-66 Nut
It could be as simple as the cover bolts are a little loose. It would probably be a good idea to change the oil in the rear end. The rear end oil is one of the most neglected parts of vehicle maintenance. It will just cost you a couple quarts of gear oil and a cover gasket.
Old 06-28-2013, 12:17 AM   #34
Captainfab
60-66 Nut
'70-'74 Impala/Caprice, '82-'02 S10, '88-'98 full sized pickup, '67-'70 pickup, and '80-'90 G series van.
what boosters are ur brakets made to use?
Thread Tools
Display Modes
