Old 11-06-2013, 06:43 AM   #26
Re: Gas Tank Capacity
The fact is,there was only one size tank in all these trucks and they are 21 gallons. I can't explain why some have taken much less when the tank was thought to be empty. If those unable to put nearly that much in really want to get to the bottom of this (get it?) you should try draining your tank dry,then fill it up. You can drain from the outlet line,but there will still be fuel in there. With the cap on,you can use compressed air to pressurize the tank to purge more,but an unknown amount will still remain. The best way is remove the tank so you can completely drain it by moving it around as needed
Old 11-06-2013, 07:17 AM   #27
70Custom10Nut
70Custom10Nut's Avatar
It'll take 21 Gallons, but the first time you turn hard to the right, like and on-ramp to the expressway, gas will come out of the filler neck. I've learned to stop filling at no more than 17-18 gallons when on a longer drives. Around town I stop when the needle hits full (About 15-16 gals). The Liquid Gold is too valuable to splash out the filler neck into the air.
70Custom10Nut is offline   Reply With Quote
Old 11-07-2013, 03:57 PM   #28
VDOG
Grand PooBaa Member
VDOG's Avatar
Does not have to be filled up to come out of the filler neck from my experience.
VDOG is offline   Reply With Quote
Old 11-07-2013, 04:51 PM   #29
leddzepp
Moderator
leddzepp's Avatar
If they hold 21 gallons than I am making out like a bandit at the pump. Been bone dry dead outta gas and pump says only 13 gallons...so maybe I'm getting like 8 gallons for free!!! Woo hoo!!!
Seriously though, in the grand scheme of my life I really don't care how much they hold.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-08-2013, 11:31 AM   #30
VDOG
Grand PooBaa Member
VDOG's Avatar
Well for me I wanted to know due to the fact that if I decided to make a long distance run, I would like to actually know how far I can go with my tank.
Old 11-08-2013, 11:36 AM   #31
71K20chevy
71K20chevy's Avatar
Because by the time you figure out how much it holds...it needs to be filled again
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 11-08-2013, 11:41 AM   #32
leddzepp
Moderator
leddzepp's Avatar
Very true!
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-08-2013, 11:03 PM   #33
No "if" to it. They are 21 gallon.
Old 11-08-2013, 11:11 PM   #34
Lee H
Lee H's Avatar
Hi Vince, long time no see. The only real way to pull off what your trying to is to run it dry (carry a gallon or two) and then fill it up and see what it takes. As this thread illustrates they are all different. When I fist got mine it ran out at 1/4 tank and took 19 gallons to fill. Now I fill up at 1/2 tank and usually takes 14-15. Works fine for me. Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-08-2013, 11:24 PM   #35
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by dlh760 View Post
The most I've ever been able to put in mine was about 16.5 gallons. That's with running out of gas pulling into the gas station ,taking off the cap, shining a flashlight down inside to see a literally dry tank then filling up until it spilled out slightly. So I would have to say its a 16 gallon tank and from what I can tell it is the original tank in my truck. Dan.
Ding ding we have a winner !
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-09-2013, 04:47 PM   #36
VDOG
Grand PooBaa Member
VDOG's Avatar
Hey Lee, hope to see you on the 24th at Legends.
Randy said the same thing about the extra gallon and run out. I have filled it up from empty before. Thats why I asked because I saw in cab replacement tanks at 21 gallons. Figured that was an upgrade since mine did not hold as much.
Had not planned on ruffling a few feathers on this subject, just wondered what size we had. Obviously my tank has a few issues for whatever reason.
Thread Tools
Display Modes
