Old 11-06-2013, 03:12 PM   #26
teamssc
Re: Looking for a points distributor
Originally Posted by manimal View Post
any points distributor for a Small Block Chevy OR Big Block Chevy will work...EXCEPT for the BIG truck 366/427.
preciate it. Wish I could find some older parts to vehicle list. Because most if the available distributors are old I can check what they are compatible with.
Found the regulators for $12 to $50 on Rock Auto. Same with coils (if I can't find the one I thought I had squirrelled away).
teamssc is offline   Reply With Quote
Old 11-06-2013, 04:39 PM   #27
geezer#99
geezer#99's Avatar
Besides a resistance wire and a coil you'll need a coil mount, new plug wires and a solenoid on your starter that has an 'I' terminal on it.
Old 11-06-2013, 04:44 PM   #28
teamssc
So the plot thickens. Thanks for the tip about the starter and bracket. I'll check the wires but it seems like they should work. There was an extra wire for the coil in the box I saved.
Old 11-06-2013, 04:52 PM   #29
Layrokr
Layrokr's Avatar
You said you found some on ebay. Did you buy one? I have a points dist. on the shelf. Installed it , ran it for about 5 mins.took it back out so it's practically new. Not sure what shipping would be. Let me know if your interested.
Layrokr is offline   Reply With Quote
Old 11-06-2013, 04:53 PM   #30
manimal
manimal's Avatar
Wasnt the "I" terminal on the starter just for 12v at start? Then in "RUN" it was reduced by the resistor wire?
Like I said...ANY distributor from a 265-454 will work in your engine...does not matter what vehicle you remove it from.
Good luck in your adventure. I am considering changing to points in my '79 F350!...a LOT less wiring under the hood.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 11-06-2013, 05:04 PM   #31
geezer#99
geezer#99's Avatar
You're right about the 'I' terminal.
Didja' know even less wiring if you put a chevy hei conversion dizzy in your Ferd. Just a 12v supply.
Old 11-06-2013, 07:52 PM   #32
Unca
I can think of a few reasons to go points, but most of them are mooted by the fact that HEI is so user friendly. I cant remember the last time I saw a matchbook cover ( point gap measuring tool of choice for roadside repairs....kind of dating myself aren't I) a dwell meter... oie vey!!! I THINK I MAY still have one out in the shelves in my barn... come north n ill help you install a new HEI... cost around 100 bucks. and some beers while we play w our squares
Unca is offline   Reply With Quote
Old 11-06-2013, 07:55 PM   #33
Unca
Bias ply tires.... cold morning massage..LOL I ran them on my jeep... 8 ply tsl boggers... it took like 3 miles to make them stop thumping
Old 11-06-2013, 10:25 PM   #34
Sodell
Sodell's Avatar
I have a dwell meter in my specialty tool box......Matchbooks worked pretty well!!!
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 11-06-2013, 10:33 PM   #35
manimal
manimal's Avatar
Sorry to hijack...but not sure if an HEI will clear the thermostat housing?
-Lance
Old 11-06-2013, 10:46 PM   #36
teamssc
Haven't bought anything. Thanks, I'll PM you.
Old 11-06-2013, 10:51 PM   #37
teamssc
I do have my trusty Sears Penske dwell meter, timing light and analyzer from back when I had the Nova. I'm sure a little Windex and it will clean up and just be fine.
Thread Tools
Display Modes
