12-06-2013, 08:45 PM | #26 |
Re: How'd you remove your cab?
I pulled mine off with the doors on using a eng hoist. It helps to have 1 that will extend out a good bit, some don't. If you build a cab cart I'll give you a heads up, don't do it like the guy did mine. I got it with the truck, but he built it so my hoist won't roll under it. You need it where you can roll your hoist under it so you can drop the cab on. Plus he built ti for a 6 ft 5 guy when he was only around 5 ft 8. Don't think there was much planning there.
12-06-2013, 09:52 PM | #27 |
12-06-2013, 10:06 PM | #28 |
whats that attached to in ceiling?
12-06-2013, 10:10 PM | #29 |
I anchored a 2"X6" flat across the 3 of the 2"x6" rafters. The eyebolt is 12" long and secured to the flat 2"X6" with washers and nuts on both sides of the board. I'm sure it's good for way, way more weight than the cab weighs.
The sling and the crank hoist both came from HF. |
12-07-2013, 01:56 AM | #30 |
I have a 20 foot huge metal beam across my garage..like an ibeam . This thing is huge...but what could I use on it to pull up the cab? Wouldnt want to drill into it...maybe like some sort of hoist trolley? Dont want to spend much.... looking for ideas. thanks
12-07-2013, 06:10 AM | #31 |
Throw a chain around the beam and put a bolt through it. Now you have something to attach a chain fall or hoist to. It is very cheep and easy, I have been pulling motors this way for many years but I just have a 4x4 slid across my rafters.
1949 Five Window, 1973 Step Side, 2000 Z71 |
12-07-2013, 06:13 AM | #32 |
12-07-2013, 07:20 AM | #33 |
Moderator
On my '50 I have used the engine hoist, however the bare cab (no doors, glass, etc.) only weighs in the neighborhood of 250 lbs so the last time I needed to move it I just asked for help, we lifted it straight up off the dolly and I was actually able to walk right over the frame backwards no less and set it down. Not hairy at all...the hoist however did get away from me once.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
12-07-2013, 08:47 AM | #34 | ||
To take the steering column off, you'll need to -remove the steering wheel -remove the steering support under the dash -remove the pitman arm -remove the bolts holding the steering to the frame. -slide the steering column out of the cab through the firewall. I can't imagine taking the steering column out without taking the front clip off first. Once I did all those steps, I had to slide it down and I moved the steering box just outside the frame and it cam right out. You want be able to do that with the inner fender in the way. That being said, I think the removing the steering box from the frame is the hardest part. I had to use some vice grips on one of the bolts, and I couldn't keep turning it because there was stuff in the way, so I had to clamp down, rotate a third of a turn, unclamp, reclamp, rotate half a turn, etc. This was was the best picture I could find of my old column. The red arrows are the directions the column needs to go. I hope that helps. |
12-07-2013, 01:47 PM | #35 | |
By all means remove the doors. They weigh quite a bit and this will be the easiest time to handle them. Same goes for the glass. While the cab is still mounted to the frame is the best time to get rid of whatever you can. If you have three strong and willing friends that will work, if they are OK taking directions. Have a platform built in advance so you have a place to set it down. I've also used an overhead hoist and that is overkill. I fabricated a simple rotisserie that my '54 cab is on now. Very handy to remove all the stuff behind the dash while the cab is tilted on the passenger side. Also, if you have any welding to do such as cab floor, rocker panels, and cab corners, make sure the four mounting points are level or you may wind up with a cab where the doors won't close properly.
Gale Gorman '54 3100 '67 C20 stepside |
12-07-2013, 06:44 PM | #36 |
--Glenn-- http://67-72chevytrucks.com/vboard/s...d.php?t=345975 http://67-72chevytrucks.com/vboard/s...d.php?t=564403 |
12-07-2013, 06:45 PM | #37 |
12-07-2013, 10:36 PM | #38 |
Just watch out for those running board brackets sticking out there. Those things are murder on your leg. After 3 times I'm starting to learn', slow learner I guess.
12-08-2013, 12:17 AM | #39 | |
Ot rig but yep the gantry like 57Toy box showed is pretty handy for cabs or roofs. A few years ago I lifted the roof off this van Rolled the van out of the way and set the roof on this van the day before it snowed.
12-10-2013, 11:40 AM | #40 |
any rough guesses as to what the cab weighs?
12-10-2013, 12:17 PM | #41 |
My rough guess is 4 to 500 bare, no glass, seat, or doors. A long time ago (1970) four of us picked up the cab and carried it. I just remember thinking it was a dumb thing to do if one of us stumbled. On the plus side, it was quick.
12-10-2013, 12:25 PM | #42 |
Where did you get the gantry? That looks like it could be dismantled quickly.
12-12-2013, 07:21 PM | #43 |
I can't believe I went 48 years without this thing. I'll never go back! |
12-12-2013, 10:02 PM | #44 | |
The lift is another level (pun intended). I've had mine for 11 years, and what did I do? I parked a car on it 4 years ago and it hasn't been down since. Mom didn't raise any smart kids...
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
12-12-2013, 11:07 PM | #45 | |
Sure beats the H3ll out of the shade trees I worked under for 50 years
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
12-13-2013, 12:24 AM | #46 |
Expensive tools and big garage would help a lot .
I'm a poor boy I removed mine similar to paintman , On my 58, I lowered the frame instead of raising the cab. I had raised the rear of the truck up to remove the rear end, springs and mounts After removing the rear end and springs, ect. (note:I had removed the front sheetmetal and done a Camaro clip) I put jack stands under the cab steps and raised the cab just enough to clear the frame so it is stable I then lowered the very rear of the frame onto a furniture dolly ,the front had tires on and simply rolled the frame out from under the cab Then cleaned and painted frame, did C-notch, trying to get the bottom of the cab blasted and painted now if the weather would cooperate. After I get the bottom of the cab done ,I'll roll the frame back under ,set it down, and install the rearend . I'm doing this all outside on my slab and a half driveway (1 car garage, full of parts, tool box, welder, no room to turn around in) Last edited by 1958Warrior; 12-13-2013 at 12:48 AM. |
12-13-2013, 07:54 AM | #47 |
ya, lifts are great, but they don't do much if your garage only has a 8' ceiling.
I used an engine hoist like everyone else. But I didn't have one of those either when I started my build. I just went the poor mans route to remove my donor vehicle cab.... and that be-otch was HEAVY! floor jack, blocks, 2x4s. All alone! Very dangerous, I do not recommend this, but if the need is there. |
12-13-2013, 11:27 AM | #48 |
Last time I did it I had nothing to help me lift it. The tractor was not working and it has a front end loader. I had 6 friends help me lift it and we lowered it onto a home made cart
12-13-2013, 01:43 PM | #49 |
SolidAxel, those are some nice looking trucks. I hope to get mine there someday.
12-13-2013, 05:13 PM | #50 |
The first time we removed my cab. (Super ghetto and sketchy as hell)
The second time we were like "lets build this big mofo!!" (Way less sketchy)
WWW.TASKFORCEERA.COM '47-'59 Chevrolet Truck Clothing |
Thread Tools | |
Display Modes | |
