Old 01-13-2014, 06:21 PM   #26
nekkidhillbilly
Re: Prepping for the Power Tour
hey i have another idea for your seat woes? my original plan was to use surban buckets take off the armrest and put in a jump seat of some sort have it all covered to match up nice and neat.
nekkidhillbilly is offline   Reply With Quote
Old 01-13-2014, 06:25 PM   #27
nekkidhillbilly
also on the radio you could use one of the custom auto sounds secret audio set ups i forgot about that thing.
http://www.casmfg.com/Secretaudio.htm when these first came out they where cheap made but cas has revamped them and now they are a quality unit and they do everthing. hope im helping just trying to.
Old 01-14-2014, 10:01 AM   #28
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
You know you have to much stuff pack ratted away, when you find an Alpine on the shelf you forgot you had.... Man having kids in sports really keeps you away from your garage and you loose track of what you have .
Found my old Alpine 9827 that I thought I have given to my brother. It has CD changer controls, that I used to run an Ipod hook up in to, had to manually run the Ipod. But this saves me some money that can be applied else where to the truck.
nekkidhillbilly, thank you for your efforts, I really do like that Parrot MKi9200, just not sure it would have the power to run speakers with out an added amp like the Kicker would. Need to research it more, might be a solution for my 94 Silverado.
bowtieguy79 is offline   Reply With Quote
Old 01-14-2014, 10:13 AM   #29
Whats a power tour
Old 01-14-2014, 10:15 AM   #30
bowtieguy79
Ephesians 2:8
http://www.hotrod.com/powertour/2013...ons_announced/
7 Cities, 7 days, one of the largest of its kind anywhere in the world!
Old 01-14-2014, 01:15 PM   #31
rs72z
rs72z's Avatar
I used a van a/c compressor on my ls swap in the stock ls location. The outlets are in a little different location than the truck compressors.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 01-14-2014, 01:36 PM   #32
bowtieguy79
Ephesians 2:8
What did you do for engine mounts? The adapter plates on my engine was interfering with the compressor in its stock location.
Old 01-14-2014, 03:43 PM   #33
rs72z
rs72z's Avatar
I cut the front ear off the plate and then redrilled the holes and slid the perch that bolts on the frame back and redrilled the holes for it.
It shows how in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=350986
___________________
78 ccsb dually
5.3
4l60e
Old 01-14-2014, 03:59 PM   #34
Wasted Income
Boosted Member
Wasted Income's Avatar
See you there, Brad.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-14-2014, 05:06 PM   #35
bowtieguy79
Ephesians 2:8
This year has potential to be fun!
Old 01-14-2014, 06:12 PM   #36
nekkidhillbilly
i would love to get down to knoxville that day you guys are there but i doubt i can.
Old 01-17-2014, 12:05 AM   #37
bowtieguy79
Ephesians 2:8
Originally Posted by bowtieguy79 View Post
Rear Axle - Biggest reason for not driving it so much is in 2011 I had to do a road side axle bearing swap on a freshly installed Junk Yard axle.... ya I know rookie mistake.... It was making noise by the time I got back home from Detroit... So I am swapping to a 14bolt SF 6 lug axle from a 88-98 truck ( only 1.5" wider than original axle), and do the 6 lug rotors up front. I really want to run 6 lug wheels.
Tore the axle shafts out tonight. Confirmed that the pass side shaft is a mess. It needs replaced, if I'm going to keep this 10 bolt in the truck... May be my cheapest route...
Anyone used any offset bearings? and had any luck?
Old 01-17-2014, 04:49 PM   #38
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Looks like a good reason for a 12 bolt swap... maybe money ahead if you snag one with the correct gears and limited slip. I'd shop it.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-18-2014, 03:27 PM   #39
nekkidhillbilly
since you wanted 6 lugs you could get 88 up 10 bolt with the gov lock and 342 or 373 for next to nothing. its what they use in the new trucks with a 5.3 would be ok with yours id think.
Old 01-18-2014, 03:29 PM   #40
bowtieguy79
Ephesians 2:8
I have a 14 bolt SF already. Just not sure I want to go that route... leaning towards rebuilding my old 12 bolt.
Old 01-18-2014, 03:37 PM   #41
nekkidhillbilly
just depends on what you wanna do then. the 14 bolt would be the strongest but 6 lug swap would have to be done. another idea is the get the 10 bolt you have and stick a newer 10 bolt gov lock and gears in it. if you want to save money but build a good geared rear with some kind of posi. would stay 5 lug then. idk anything about using offset bearings though i think for the money a good shaft would be not alot more.
Old 01-18-2014, 03:40 PM   #42
bowtieguy79
Ephesians 2:8
I've checked into doing a newer style 10 bolt gov lock type swap into my older 10 bolt, from what I've read the bearings are different enough that they won't interchange.
Rock Auto has a stock replacement axle for $125, that would be the cheapest repair option. I've searched Craigslist for another used axle, man these are getting to be like a Hens tooth, just not there...
I can build the 12 bolt back up, it will be plenty strong and can retain the 5 lug rallies.
Old 01-18-2014, 05:12 PM   #43
bowtieguy79
Ephesians 2:8
Made up my mind, 10 bolt is staying in the truck. Went on Advance Auto and found a promo code that saved me some descent coin on an axle shaft, outer bearing, and seal. $125 shipped! Axle shaft is a Motive Gear, looks like good stuff.
Now on to other things!
Old 01-19-2014, 09:57 AM   #44
nekkidhillbilly
really? i thought you could guess im thinking of just the gears. glad it all worked out though. dug some you can use up to 99 after 99 nbs its the 8.6 prior is the 8.5 but can retro fit 8.6 guts in a 8.5 idk how cost effective it is. http://www.my4by.com/gm-10-bolt-8.5-...-8.6-inch.html
Old 01-20-2014, 11:12 PM   #45
bowtieguy79
Ephesians 2:8
Originally Posted by ElGracho View Post
For your AC, if you haven't already, check out these brackets Holley came out with. They actually seem to be priced reasonably and are a good way to mount an AC compressor on an LS series engine on our trucks:
http://www.holley.com/types/LS%20Swa...y%20Drives.asp
Thank you again, I ordered the Holley Brackets with Sanden 508 tonight off of Summit.
Also ordered some CPP 2.5" drop spindles.
Old 01-21-2014, 04:07 PM   #46
nekkidhillbilly
gonna be sharp
Old 01-25-2014, 02:17 AM   #47
bowtieguy79
Ephesians 2:8
Got some work done tonight, Ready for Saturday. Hope to get it back onits wheels
Old 01-25-2014, 03:34 PM   #48
nekkidhillbilly
how are you not froze to death in il right now. garage or no its too cold for me.
Old 01-25-2014, 03:52 PM   #49
bowtieguy79
Ephesians 2:8
Heated Garage
60 Degrees
Old 01-25-2014, 04:13 PM   #50
nekkidhillbilly
i need my house built so bad so i can have a garage.
Thread Tools
Display Modes
