Old 06-02-2014, 07:53 PM   #26
oldman3
oldman3's Avatar
Re: 1947 Rust repairs, Roof, A pillar, beltline
You are probably correct on the dies and the difference in parts. You and your crew have done a great job on the truck, nice save...Jim
oldman3 is offline   Reply With Quote
Old 06-02-2014, 08:45 PM   #27
dwcsr
Hollister Road Co.
dwcsr's Avatar
Thanks,
I sketched out what the difference at the windshield at the roof line are in 47 and 50. You don't notice it until you need lines to match up
dwcsr is offline   Reply With Quote
Old 06-02-2014, 09:11 PM   #28
BlueJeep
BlueJeep's Avatar
Nice job!
Now that you've done it, care to post up your thoughts on panel bonding the rear seam? It was only concept in my head, but now I'm anxious for real world experienced opinions.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 06-02-2014, 10:29 PM   #29
dwcsr
Hollister Road Co.
dwcsr's Avatar
The adhesive we used was Lord Fusor 108B it has a 40 - 50 min set time and I think a 2 hour un-clamp time so you have some room to move the panel into position.
I've weld bonded a roof before and it was real easy, lay the adhesive and basically drop the roof on and clamp it, spot weld every 8 inches, this was a little different because the panel needs to be positioned so it fits centered for the windows and still wraps around correctly to the doors. We test fit this about 5 times and once with all the clamps for the weld bonding process before we laid down the adhesive. It is a two man job not doubt about it.
The results are much better than I had anticipated. It looks nice and it will seal the seam from any future water penetration. I think this will be the way I do the seam when I do rear upper and lower cab panels.
Old 06-03-2014, 02:41 PM   #30
FarmerSid
FarmerSid's Avatar
Nice work! What did you use to bond the top and lower rear panels?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 06-03-2014, 02:53 PM   #31
dwcsr
Hollister Road Co.
dwcsr's Avatar
The product is made by Lord, called Fusor 108B, cost was about $40 with the two mixing tips. Application gun can be had for between $35 and 50 on ebay. We are doing the drip rails with it as well.
Old 06-03-2014, 03:20 PM   #32
FarmerSid
FarmerSid's Avatar
Sorry Dave for the stupid question. I had read your update earlier this morning and got busy. I didn't refresh the thread to see if there was any new posts before I posted the question.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-03-2014, 05:19 PM   #33
dwcsr
Hollister Road Co.
dwcsr's Avatar
No problem,,, I think I may try it on the cowl panels next time I do one, it would be so much quicker and easier to clean up for finishing. As long as the part is not structural you can a use this.
Old 06-07-2014, 02:30 PM   #34
dwcsr
Hollister Road Co.
dwcsr's Avatar
So here we are ready for delivery to the painter. The body is rough finished to the point they like it at.
As a note we used the Fusor 108B for the drip rails and the back panel up right. It made putting on the drip rail so much easier, glue it , screw it and once set remove the screws and plug weld the holes.
Last picture is where the A pillar was at before we started
Old 06-18-2014, 10:55 AM   #35
FarmerSid
FarmerSid's Avatar
Question for you Dave. How will that belt line seam be finished off for paint?
C4 IFS & D44 IRS
5.3 HO L33
Old 06-18-2014, 11:50 AM   #36
dwcsr
Hollister Road Co.
dwcsr's Avatar
The recommendation is to skim coat it with filler. The adhesive is always a little tacky even after drying
Old 06-18-2014, 03:28 PM   #37
FarmerSid
FarmerSid's Avatar
So it will be filled in and look like there is no seam there? What filler will be used? Thanks Dave.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-18-2014, 04:13 PM   #38
dwcsr
Hollister Road Co.
dwcsr's Avatar
They recommend you finish with fiber-filled body filler. I don't know a particular brand that has fiber strands but I'm sure you can find it.
Old 06-18-2014, 04:44 PM   #39
rgunlock
rgunlock's Avatar
I've used a product from Evercoat called Kitty Hair for similar applications. Looks like the stuff you find in a sink trap, and smells worse, but sands out pretty nice.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 06-18-2014, 07:29 PM   #40
FarmerSid
FarmerSid's Avatar
Thanks Dave
C4 IFS & D44 IRS
5.3 HO L33
Old 09-26-2014, 11:09 AM   #41
dwcsr
Hollister Road Co.
dwcsr's Avatar
Just to keep you all up to date here is a pictures of this truck as it is now. Almost finished.
Old 10-17-2014, 06:12 PM   #42
dwcsr
Hollister Road Co.
dwcsr's Avatar
For those interested here it is 99% done. It just needs a few paint touch ups, the floor mat horn button and minor odds and ends but its driving, steering and more importantly stopping
Old 10-17-2014, 06:17 PM   #43
dwcsr
Hollister Road Co.
dwcsr's Avatar
few more
Old 10-17-2014, 06:35 PM   #44
dwcsr
Hollister Road Co.
dwcsr's Avatar
The engine is 292 ci, SM420, 14 bolt rear, disc on all 4, AC from Old Air, the gauges were done by a board member Tom at Classic Gauge and Cluster. He did some custom work for me on these by adding a charge gauge from a later model that works like the 72 trucks. They used a mili-volt meter that connected at the battery and at the Alt splice to sense voltage flow, works perfectly. Cooling fan is a Mark VIII fan with a PWM controller. We moved the radiator forward to make room. It has power steering like the old school trucks did , ram assist with a control valve on the Pittman arm. The wheels were converted to tubeless by Stockton wheel keeping the old pattern and hub cap clips. Complete AAW wiring harness. Intermittent wipers.
We started 4/12 this year
Old 10-17-2014, 06:43 PM   #45
FarmerSid
FarmerSid's Avatar
Looks awesome Dave! Just awesome! A lot of very nice touches finishing it off. What did you end up using for filler on the belt line? Thanks for the update.
C4 IFS & D44 IRS
5.3 HO L33
Old 10-17-2014, 07:21 PM   #46
oldman3
oldman3's Avatar
Nice job on the rebuild, boy that is a long puppy...Jim
Old 10-17-2014, 07:23 PM   #47
dwcsr
Hollister Road Co.
dwcsr's Avatar
Thanks, it seems to get longer each time I look at it. It turns like a bus
Old 10-17-2014, 07:23 PM   #48
dwcsr
Hollister Road Co.
dwcsr's Avatar
They used some Dynatron 462 Dyna-Glass Short Strand Body Filler
Old 10-18-2014, 02:47 AM   #49
47 Fasttoys
47 Fasttoys's Avatar
Very nice overall Dave. I see you have a few modern touches on it but, I gotta say those LED brakes on the back....no way. Maybe not your choice. Great overall.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 10-18-2014, 10:23 AM   #50
dwcsr
Hollister Road Co.
dwcsr's Avatar
Rob
Thanks,
The lights were customer choice, Here in Houston its not if you get rear ended its when and he wanted people texting, reading books or doing make up to be able to see the brake lights. This truck is high enough that a Honda or toyota would go under up to the axle.
Thread Tools
Display Modes
