#26 |
![]() Join Date: Oct 2013
Re: truck doesn't start
I hooked up a jumper wire from the + of the coil to the battery and the truck jumped.
#27 |
I got it running guys! So you guys were right, points were dirty. It had gummy oily gunk on it. I wiped it as much as I could with a paper towel and it started up! So whats the best way to clean it?
p.s. I also found the small arm that connects the choke! |
#28 | |
#29 |
good job
project: "my happy mess" |
#30 |
I think I didn't clean the points. What I cleaned was the motor shaft part that moves the point. However it looked like it wasn't even touching the point. Are those mechanical spring piece removable? If I can remove it I can see the points. As it stands now I can't see the points.
#31 |
Did you do anything else before or during? You might be able to spray some contact cleaner in there. Something that leaves no residue and dries quickly. Try doing a google/youtube search for disassembly. It's been decades since I've had to service a distributor, so I'm not much help there. Does the truck run OK, GOOD? Did you hook that linkage back up? Did you rewire the 'de'-choke?
like ![]()
#32 |
alright, yeah that was the points. I cleaned it more. I also reattached the choke arm. it starts right up like a champ! thanks guys! I knew you could solve it.
#33 |
good job, again
Thread Tools | |
Display Modes | |
