#26 |
Re: Best Replacement Radiators
I bought an Ebay special when I installed my new engine. It was easy to install and it works great. All aluminum for $172
http://www.ebay.com/itm/3-Rows-1967-...item51aef2599c
-Jason USN Retired |
#27 |
I am going to have to do a custom radiator because of my Trailblazer engine swap which basically changes inlet and outlet position, left for right. Of the companies that would do custom, Ron Davis was far and away the best package for me. All aluminum, well constructed, high quality fans with a very well planned and executed shroud and made to fit into the C-10 mounts.
They sent me example pictures and CAD drawing for the whole thing. I still haven't ordered it, but am about to. I also got information from other vendors but they were either beyond stupidly expensive or were a hack of an off the shelf piece. Ron Davis was going to make it from scratch (not that the Ron Davis wasn't expensive, it is, but I thought it was more reasonable by comparison).... FWIW. Most of the radiator companies (like transmission builders) have their haters on internet forums in one place or another, Ron Davis seemed to have a lot more good press than bad when I researched it and they do offer very nice and lesser priced drop ins for our trucks in all the typical configurations, 2 and 4 core sized and with or without integrated trans cooler as well as shrouded electrics. |
#28 |
Chance
![]() Join Date: Sep 2001
Well I inboxed the Murray/vista pro 433366. It is aluminum with a plastic tank. I sure hope it holds up. We will see.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
#29 |
Late to the Party!!!! Addco fit perfect!!!
#30 |
Chance
Put the radiator in this morning. It's about 80f and the truck is running cooler than it used to. I am still not too happy about part of the radiator being plastic. Oh well, as long as it last a long time I should not complain. The real test will be when it is in the 90s and I'm pulling a bobcat on a utility trailer.
#31 | |
I would be disappointed with plastic tanks too. Most cars and trucks built in the last 20 years or so have them and they last reasonably well. This is another example of the aftermarket DIY industry trying to consolidate the shear number of parts. I've seen this with other parts as they try to make parts that will fit many cars VS a few.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#32 |
![]() Join Date: Nov 2001
It seems that all radiators manufacturers are moving to the plastic/aluminum radiators due to the high cost of copper/brass materials. I know the company we sell has plastic/aluminum radiator in the box when selling a radiator for our trucks. They are an ok radiator and if you ever split/break a tank, you can just replace the tank as these are available.
But it still doesn't look right in these trucks... I still prefer a rebuilt OE radiator using a new core, even though it may be more expensive.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#33 | |
Registered Cruiser
There's nothing wrong with the new style radiators, but you're correct when you say "doesn't look right". We're all used to seeing that black four core OEM Goliath that belongs there. I've got one of the O'reilly's radiators. After ten years, it sprung a leak, and they gave me a new one. That was five years ago. I wonder what they'll replace it with next time?
I intend to live forever. So far, so good. |
#34 |
I've put in 3 or 4 Champions in different applications and only had one issue. One of the trans cooler line fittings had some messed up threads. The owner already had an external cooler, so instead of returning it, he told me to just use the external cooler only. Two of the installs were on air conditioned cars and in our July-September high heat/high humidity climate, no problems in traffic.
Steve McMillen ASE and GM certified Master Technician 25 years+ experience ![]() No, I do not know it all, that's why I attend tons of training. |
#35 |
![]() Join Date: Dec 2013
ive got the thick griffin rad in my 69...just trimmed the rubber cushions a lil to use the oem brackets but i plan on making some to fit/look a lil better.
#36 |
Chance
Well I am going round two with this one. The radiator on my other truck (1968 w/396) has a pin hole leak. I think I am going go with the all aluminum radiator from speed cooling. I will keep you all posted on this.
So much for the Devils Run Car Show I was going to bring my 1968 to this weekend...
#37 |
Do you guys have any experience with the vista pro 433369 or the champion mc369? I have a 1969 c20 with a v8 and air conditioning.
#38 | |
Thanks, Robert |
#39 | |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
#40 |
Z10, Very nice! That's exactly what I was looking for. Thanks!
Thread Tools | |
Display Modes | |
