Old 08-03-2014, 07:21 PM   #26
chris1htx
Re: wiring harness for electric fan
Ok guys I am in need of your assistance. I got the fan, the wiring kit, and everything set up. Because of clearance issues I had to remove the studs that was holding the mechanical fan and replace them was bolts. When I go to start the truck the pulley that was holding the fan is not moving, the pulleys behind it are moving. Any suggestions in what happened? Do you guys think I have the bolts too tight?
chris1htx is offline   Reply With Quote
Old 08-03-2014, 07:52 PM   #27
rich weyand
rich weyand's Avatar
Post a pic. My suspicion is that you have bolts that are too long and they are catching on the water pump housing. There's little to no clearance behind the water pump flange. I can't remember if I used 1/2" or 3/" bolts, but they're short and even so it's close.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 08-03-2014, 08:20 PM   #28
chris1htx
That's what I was thinking too but if the bolts were too long why would the pulleys behind the main pulley be able to move? I'll post a pic when I get a chance
Old 08-03-2014, 08:40 PM   #29
rich weyand
You really meant "behind"? I thought you meant "below" and it was just a spell-check thing.
Rich Weyand
1978 K10 RCSB DD.
Old 08-03-2014, 08:48 PM   #30
chris1htx
No sir it's behind. I am clueless right now
Old 08-03-2014, 10:25 PM   #31
piecesparts
Parts and more parts
piecesparts's Avatar
I agree, the bolts are too long.
Frank
piecesparts is offline   Reply With Quote
Old 08-04-2014, 12:58 AM   #32
rich weyand
We need pics.
Rich Weyand
1978 K10 RCSB DD.
Old 08-04-2014, 08:52 AM   #33
chris1htx
I wasn't able to get a pic of the new set up yet but here's a pic of the pulleys i am talking about
Old 08-04-2014, 10:14 AM   #34
notallthere
I replaced those on mine with just some Grad 5 bolts I had in the shop.
notallthere is offline   Reply With Quote
Old 08-04-2014, 08:22 PM   #35
nekkidhillbilly
i had lt1 fans on my dads truck since about 03 when i had it. used just a temp probe. i will say this stay away from flex a lite controllers (mine melted even properly better than what it recomends) go with derale. but the derale probe temp controller has worked flawless since about 03.
nekkidhillbilly is offline   Reply With Quote
Old 08-05-2014, 11:45 AM   #36
hatzie
Moderator
hatzie's Avatar
There's a pretty good thread on the 90's Lincoln MK VIII and Taurus fans on the MK VIII forums. http://forums.tccoa.com/showthread.php?t=136722
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-05-2014, 01:34 PM   #37
piecesparts
I have looked at the Taurus fans on the web and they are out there. Many claim that they move a lot of air, but I am one to not spend time running around to salvage yards looking for what I want and then burning up time and gas to not find it. I went to a new fan made by SPAL and I have had no issues with the fan sets that I have installed in a couple of trucks. I have another fan set in my basement waiting on my next project and I will use it when I get to the point.
Frank
Old 08-05-2014, 02:03 PM   #38
Jabes1
Jabes1's Avatar
Easy fix.. use the original bolts along with the original fan spacer, minus the fan. Ran mine that way for two years until I switched to serpentine.
Welcome to my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=574370
Jabes1 is offline   Reply With Quote
Old 08-05-2014, 05:13 PM   #39
piecesparts
To clean it up, double nut the studs out of the water pump pulley faceplate and then replace with a short bolt that is the length of the thickness of the pulley and the water pump shaft faceplate. I put new ones in my 91 truck that were allen head, so that they were cleaner. Use Loctite to ensure they stay set.
Frank
Old 08-05-2014, 05:35 PM   #40
gmachinz
I've done this two ways-go to Lowe's or Home Depot and get some 5/16-24 button head machine bolts which are Allen head or- if you have a chamfer bit, chamfer the holes so that you can use a tapered Allen head bolt so the head sits flush with the surface of the pulley-much nicer look than using regular bolts-and get the black oxide ones-dont get reg. bolt finish. Put it all together, mask off a bit and dust it all with a stain black and it looks sharp!
gmachinz is offline   Reply With Quote
Old 11-25-2014, 11:02 PM   #41
sgr60
Are these the types of fans that people have used from a Windstar?
http://www.ebay.com/itm/99-03-1999-2...20e53d&vxp=mtr
I had a Tahoe a while back that I put electric fans in - out of a Camaro I think - they worked amazingly well. Would like to make the conversion on this truck as well.
You just get the fans and then buy some kind of a temperature controlled switch? Like this harness?
http://www.summitracing.com/parts/der-16759/overview/
Looks pretty doable...
'84 K20 350/465/208
sgr60 is offline   Reply With Quote
Old 11-25-2014, 11:57 PM   #42
gmachinz
Those types of universal fan kits don't work with factory type dual speed, series wired fan motors generally. I would suggest a more stout fan harness-I can provide one if needed but there are others who offer them as well-but, it depends on the type of fan(s) you plan on running.
Old 11-26-2014, 10:03 AM   #43
sgr60
So those Fans are ok, just need a better harness? If you've got something you make - like a prewired harness - that would be great.
'84 K20 350/465/208
Old 11-26-2014, 11:58 PM   #44
86c20
86c20's Avatar
on all the diesel site i am on we use a turse fan. think they are some where in the 28-3200 cfm and work with the rad intercooler and ac also up hill with a load keeps everything in check. i will be doing this this winter to 3 or 4 trucks gas and diesel. we have a lot of stop and go here and alot of sitting.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Thread Tools
Display Modes
