Old 08-05-2014, 09:23 AM   #26
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Should I replace my fuel pump or get a shop to do it?
Originally Posted by 70's luvr View Post
I just did it last week. Did it all from underneath as was difficult from the top with the AC pump there. Without that it would be a breeze. I used grease to hold the rod up and bumped the motor over so it was retracted in the block
Yeah... I changed mine MANY years ago when I had no A/C. Piece of cake. Added a Vintage Air sanden compressor and bracket and it was quite the pain in the ass when I installed a new one recently. I also used a little dab of grease.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-05-2014, 09:24 AM   #27
sboris
sboris's Avatar
Originally Posted by Ironhorse View Post
I've used a hack saw blade or long skinny screw driver many times to hold back the fuel pump rod. Just slowly remove the hack saw blade/screw driver as you insert and rotate upwards on the fuel pump being sure the pump arm is "under" the pump rod. Insert and finger tighten the mount bolts. I also use RTV on the pump housing with the gasket. Allow the RTV to "tack" some before installing the gasket.
I also have always packed the cavity of the fuel pump housing with grease as an old mechanic years ago told me GM fuel pumps were prone to not receiving enough oil to lubricate the pump arm after installed.
Anyone else do the grease in the fuel pump housing trick?
Yes I do the same thing. Especially if it's a vehicle that sits a lot.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 08-05-2014, 10:42 AM   #28
4oldcars
4oldcars's Avatar
JCD's way is the key. A scrap piece of tin will work.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 08-05-2014, 10:54 AM   #29
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I've changed probably 30 or 40 SBC and BBC pumps in my life. Never rotated the engine, never used grease, never used the "upper bolt", never used anything to hold the rod up in the block.
disconnect the fuel lines, and unbolt 2 bolts and pull the pump out. The rod will slide down against the pump plate. Grab new pump and while pushing the rod up with your fingers up into the block, make sure the pump arm is below the rod and put it in the opening and hold it there with the pump arm. Grab your 2 bolts put them through the pump body and get them started in the holes. It the rod is keeping the pump from seating all the way, keep slowly tightening the bolts a little bit one at a time until the pump sits flush with the block. If this happens you're actually depressing the pump arm (plunger) as you tighten. No biggee... reattach fuel lines and make sure not to put a twist in the metal line to the carb. Use flare wrenches...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-05-2014, 01:31 PM   #30
In The Ten Ring
OK. I might try it today!
Thanks for all the advice. And, I've learned what "flare wrenches" are for.
In The Ten Ring is offline   Reply With Quote
Old 08-05-2014, 08:19 PM   #31
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
It's already been mentioned but I use the hacksaw blade method, Dad taught me that many moons ago.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Thread Tools
Display Modes
