Old 10-05-2014, 09:02 PM   #26
slammed48
slammed48's Avatar
Re: My 73 pickup...parts hauler/work truck
Originally Posted by Jake Wade View Post
Hey, I am only about 80 miles from you. What headers are those? What Isky grind did you go with? What are the tire/wheel sizes?
They are Sanderson street rod blockhuggers, good quality, but super short...meant purely for applications with no space.
Isky 270 Mega
slammed48 is offline   Reply With Quote
Old 10-05-2014, 09:06 PM   #27
slammed48
slammed48's Avatar
few more pics...
Stance!
This pic is with ~500lbs in the bed weighing it down.
Old 10-05-2014, 09:09 PM   #28
slammed48
slammed48's Avatar
Iola, Wisconsin Swap meet:
Street Rod Nationals in Louisville, KY:
Old 10-05-2014, 09:12 PM   #29
Jake Wade
Jake Wade's Avatar
That back tire/wheel combo is PERFECT! I would guess a 4" back space wheel.
Jake Wade is offline   Reply With Quote
Old 10-05-2014, 09:17 PM   #30
slammed48
slammed48's Avatar
HAMB drags in Joplin, MO
Old 10-05-2014, 09:20 PM   #31
slammed48
slammed48's Avatar
thanks...pretty much, 3.75" to be exact.
Old 10-05-2014, 09:25 PM   #32
slammed48
slammed48's Avatar
Then to Alabama...
Old 10-05-2014, 09:29 PM   #33
Hubscrub
Cruzin
Hubscrub's Avatar
These pics keep getting better!
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-05-2014, 09:45 PM   #34
slammed48
slammed48's Avatar
Then I decided to make a few changes...
back out...
Old 10-05-2014, 09:50 PM   #35
slammed48
slammed48's Avatar
I've never understood why rear axles don't have drain plugs from the factory?...So I added one in the cover and a fill plug that's easier to use than the one on the front side.
may not look so great, but the benefits outweigh that.
Old 10-05-2014, 09:58 PM   #36
slammed48
slammed48's Avatar
Aluminum heads, and chromemoly roller rockers...smaller combustion chambers to bump up the compression ratio, and 1.6 ratio rockers to increase the lift to work better with the heads...
Old 10-05-2014, 10:04 PM   #37
slammed48
slammed48's Avatar
For future reference for anyone else... the port location in relation to the spark plugs on these Promaxx heads was just different enough from the stock heads that my old headers wouldn't work.
I ended up modifying some old headers I had to work...total Pain!
Headers are something I think it's worth paying up for to get some good quality ones...I plan to change them sometime in the future.
Old 10-05-2014, 10:07 PM   #38
slammed48
slammed48's Avatar
back in:
Old 10-05-2014, 10:20 PM   #39
slammed48
slammed48's Avatar
and here it is running again: http://youtu.be/_f1HS7nTA8k
Old 10-05-2014, 11:09 PM   #40
CircusWagonJim
CircusWagonJim's Avatar
Great truck!!!
CircusWagonJim is offline   Reply With Quote
Old 10-05-2014, 11:10 PM   #41
Desperado454
Desperado454's Avatar
Cool truck!
Twin Turbo '76 C10 Build
'28 Model A Build
-Brooks
Desperado454 is offline   Reply With Quote
Old 10-08-2014, 10:03 AM   #42
MikeB
MikeB's Avatar
Originally Posted by slammed48 View Post
close... 15x7 215/70/15 and 15x8.5 255/70/15
I like a little bit narrower front tire than most guys.
At your front ride height, do you think a 255-60 tire would clear the front fender lips on 15x8 rally wheel (4.25" backspacing)?
How much drop did you get with the Belltech spindles and flip kit? And how does the flip kit work? I've never done anything with rear leafs other than remove/install them.
My 82 C10 (below) has 6.5" van rallys installed by some previous owner, but they sit inboard way too much. I had planned to go to wider rallys, but was gonna keep it at stock height until I saw yours!
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-08-2014, 03:03 PM   #43
Malo83
Cruzzzn' Vet
Malo83's Avatar
Nice!!!
Classic Old Skool
Malo83 is offline   Reply With Quote
Old 10-08-2014, 03:08 PM   #44
Low Elco
Diggin' it! don't change a thing!
Low Elco is offline   Reply With Quote
Old 10-09-2014, 05:25 AM   #45
slammed48
slammed48's Avatar
It may fit...it would be tight and I don't think it would look very good anyway...but I realize most guys use bigger front tires.
It's about a 6" drop in the front, not sure exactly in the rear.
A "flip kit" relocates the axle so that it sits on top of the springs (rather than below the springs as it is in stock form) Then the frame is notched above the axle to allow for up and down travel of the axle.
Old 11-08-2014, 09:08 AM   #46
slammed48
slammed48's Avatar
Headers!
Old 11-08-2014, 09:13 AM   #47
slammed48
slammed48's Avatar
Old 11-08-2014, 04:55 PM   #48
SCOTI
SCOTI's Avatar
Headers!
Will those work w/o mods to you heads (since the other ones required tweaking)?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-08-2014, 08:10 PM   #49
mickeykreg
mickeykreg's Avatar
Awesome man! I dig the working pics from out on the road.
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 11-08-2014, 09:05 PM   #50
slammed48
slammed48's Avatar
Yeh...no issues with the Stan's headers..
Thread Tools
Display Modes
