Old 10-08-2014, 06:59 PM   #26
bs46488
Re: 1972 Longbox looking to become a shortbox
That's a bad a*% template. If you can make those out of wood, cutting the box sides should be no issue at all.
I'd consider myself advanced beginner and I was able to cut my bed sides down. My final cuts look better than the first. The more you measure and clean your edges after the cut, the better the fit.
Here is my box right after I sliced the back off:
bs46488 is offline   Reply With Quote
Old 10-08-2014, 07:00 PM   #27
dacavy
I thought about ordering the bed sides. Who should I order the bedsides through to get the best ones? Do they have the inner and outer sheet metal when you order the sides.
dacavy is offline   Reply With Quote
Old 10-08-2014, 07:17 PM   #28
Xeen
Xeen's Avatar
Yeah they are complete.
As far as who to order them from it's not too complicated but it will take some phone calls to find out how much they weigh apiece. If they try to tell you that they don't have that information they are either being lazy or don't know that they can find out by how much they cost to ship.
Interesting story: I went to order some short fleet bed sides from classic industries and it turns out their 1967 bed sides weigh more by nearly 20 pounds per side than their 1968-72 bed sides so combined they are 40 pounds heavier which means they are most likely produced using OE gauge steel.
The point being that you want to find some 1968-72 short fleet bed sides that are OE gauge steel and you will have to call around to find them.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-09-2014, 01:10 AM   #29
Turbo1dr
Turbo1dr's Avatar
For some reason I don't like putting bondo all over a vehicle. I'd rather just go in debt and buy a complete short bed box than to have to cut and weld one to shorten it. At least buying a new one, you will have a guaranteed straight body. After painting a cut-down bed, you might realize your bondo work may not be so great.
I'm pretty sure (when i get to my truck) I will shorten it.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
Old 10-09-2014, 01:09 PM   #30
dmack91
dmack91's Avatar
I guess I look at it this way. First, I am cheap and the truck will be a play truck, not a show truck. Body work is a challenge and I want to see how it will come out. If you don't like the results of cutting it down, buy the new SB panels and the only thing you are out is your time (mine time is free).
Either way, keep us posted.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Thread Tools
Display Modes
