Old 08-18-2003, 06:45 PM   #26
rambler
MOVE OVER
rambler's Avatar
Originally posted by Hotrod70C10
Here's my dub city truck after I lifted the rear a bit and put some different wheels on it. Now it doesn't look like it has 30" rims on it lol
I like the looks of that one much better!
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 08-18-2003, 06:50 PM   #27
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Thank you sir!
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 08-18-2003, 08:14 PM   #28
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Wix blazer pic's
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-18-2003, 08:16 PM   #29
FRENCHBLUE72
PROJECT 7DEUCE
MEMBER #6377
Project "7DEUCE"
Old 08-18-2003, 08:19 PM   #30
FRENCHBLUE72
PROJECT 7DEUCE
MEMBER #6377
Project "7DEUCE"
Old 08-18-2003, 08:21 PM   #31
FRENCHBLUE72
PROJECT 7DEUCE
more
MEMBER #6377
Project "7DEUCE"
Old 08-18-2003, 08:24 PM   #32
FRENCHBLUE72
PROJECT 7DEUCE
Last one!!!
MEMBER #6377
Project "7DEUCE"
Old 08-18-2003, 08:55 PM   #33
Hotrod70C10
Low & Slow
Hey Frenchblue72, is there any chance that the 69-70 grille on that blazer would fit on the dub city truck? If so i'm going to have to find one of those banks and swap them. thanks in advance.
4.5/6 drop
Old 08-19-2003, 06:10 PM   #34
FRENCHBLUE72
PROJECT 7DEUCE
Sorry the wix bank is to narrow.
MEMBER #6377
Project "7DEUCE"
Old 08-19-2003, 06:30 PM   #35
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
I was thinking the same thing. Too bad.
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline   Reply With Quote
Old 08-19-2003, 08:31 PM   #36
Hotrod70C10
Low & Slow
That sucks.....
4.5/6 drop
Old 08-20-2003, 01:00 AM   #37
FRENCHBLUE72
PROJECT 7DEUCE
Some one on here got a pannel off of e-bay awhile back . I can not remember who ????
MEMBER #6377
Project "7DEUCE"
Old 08-20-2003, 01:01 AM   #38
FRENCHBLUE72
PROJECT 7DEUCE
Anyone know if the wheel's just pull off or how would I go about putting new one's on???
MEMBER #6377
Project "7DEUCE"
Old 08-20-2003, 01:49 AM   #39
Hotrod70C10
Low & Slow
hey frenchblue72, the wheels just pull off. Turn them just a little while holding the opposite wheel. they will pull off after a few twists. The rod they are mounted on looks like a file. hope that helps oh, I used regular model car wheels that I had from a buick gsx. I'm thinking about finding some different wheels and some big wide rear tires for it though. Oh if you use the standard little model car wheels and tires you will have to make a new rod that is longer for the wheels to mount onto.
4.5/6 drop
Old 08-20-2003, 10:47 AM   #40
69sixpackbee
I like 'em except for the funky-ass "Homeboy" wheels
69sixpackbee is offline   Reply With Quote
Old 08-20-2003, 04:14 PM   #41
dinnut
dinnut's Avatar
i took the bed off mine and dont see how to lift it... how do you lift/ lower these?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 08-20-2003, 04:31 PM   #42
trinic
trinic's Avatar
here's a few pics of my diecast
I need to replace the wheels with some nice ralleys......
Truck use to be the silver one, but I sanded and filled in the trimming, etc. Tried to match color of my truck...
Enjoy.
trinic is offline   Reply With Quote
Old 08-20-2003, 04:56 PM   #43
Hotrod70C10
Low & Slow
Lifting it up is easy but you can only do it just a little bit. If you pull the "axle" out of the truck and run it in the slot under where it actually goes. You might have to drill it out a bit though. If that doesn't make any sense i'll get some pics of it for you.
4.5/6 drop
Old 08-20-2003, 06:00 PM   #44
rambler
MOVE OVER
rambler's Avatar
Sounds like we might need to do a another board.. the Dub city, 1/24 or 1/18th, scale kit truck board....
Buckaroo Banzi
Old 08-20-2003, 07:17 PM   #45
Chevy_68
Chevy_68's Avatar
yo trinic how did you fill in the moulding bondo or whati doing the same thing on mine makeing it look how i want my truck to look like when its done
Chevy_68 is offline   Reply With Quote
Old 08-20-2003, 09:30 PM   #46
FRENCHBLUE72
PROJECT 7DEUCE
Thank's for the help guy's .. Trinic look's like you got some time into that . Look's good.
MEMBER #6377
Project "7DEUCE"
Old 08-21-2003, 08:46 AM   #47
trinic
trinic's Avatar
bondo, bondo, time, time
I used the bondo that comes in a squeeze bottle (ready to use). Took me a while to try and get the cracks filled in. Sanded, primered, sanded, primered, etc... Didn't come out perfect, but It was my first shot at it.....
Thx,
PS- As you can see in the first picture I tried to make the cab a small window (like my truck), but the bondo didn't hold up.....
T.C.
Old 08-23-2003, 04:32 AM   #48
Andy4639
Old member
Andy4639's Avatar
Cool 1/24th scale, and 1/25
Here are some of mine that I have done. The trucks are 1/24th and the panel is 1/25.
I know the pics arn't that good.
I will have to post a couple of times.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-23-2003, 04:35 AM   #49
Andy4639
Old member
Andy4639's Avatar
Cool 1/24 truck
Another
Old 08-23-2003, 04:39 AM   #50
Andy4639
Old member
Andy4639's Avatar
Cool and another
Here are a few places you can order from also.
www.Milezone.com
www.atkins.com They are the two I order from.
Thread Tools
Display Modes
