Old 11-25-2014, 10:29 PM   #26
sgr60
Re: Vacuum lines and emissions components
Here is what my vacuum lines look like now - if anyone sees any issues that I might have please let me know. I do want to keep to vapor can so that the fuel tank can vent there. I also want to make sure that I have the vacuum advance for the distributor connected to a proper port on the carb - is the same as it was, but with all the stuff in the middle removed.
At the moment, it seems to run better than it did before...
'84 K20 350/465/208
sgr60 is offline   Reply With Quote
Old 11-28-2014, 01:16 AM   #27
sgr60
Any thoughts on the above vacuum routing?
'84 K20 350/465/208
Old 11-28-2014, 01:38 AM   #28
K5owner
EGR valve cannot be replaced with a breather. You must use plate to physically block off the mount on the manifold. Other then that yeah that looks good. I would just replace the intake manifold with an aftermarket of your choice and delete the EGR entirely.
K5owner is offline   Reply With Quote
Old 11-28-2014, 03:58 PM   #29
sgr60
Thanks - EGR is out, covered with a plate.
'84 K20 350/465/208
Thread Tools
Display Modes
