#26 | |
Re: Gas Tank Relocate HELP PLEASE!!!
#27 |
![]() Join Date: Mar 2011
Here's what I used. The 64-67 Mustang/Falcon tank.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#28 | |
#29 |
PDXHall did you modify resistance on Mustang sender for fuel gauge if so how? All of this resistance stuff is baffling to me!!
#30 |
I'm going with aftermarket gauges so I just ordered a gauge that matches the Mustang sender. I believe there is someone on the board here that did a write up on modifying the sender. I'll see if I can locate it.
#31 | |
#32 |
![]() Join Date: May 2010
I have been thinking about using 1969 Camaro fuel tank set up for fuel injection for my LS swap in my 66'.
Something like this: http://www.ebay.com/itm/New-1969-Che...p2054897.l4275
It only has original paint once |
#33 | |
http://www.classicparts.com/mobile/1...5/#.VJOhaBAAIF Couldn't you turn that into one for fuel injection for cheaper than the one you mentioned? |
#34 |
PDXHall do you have any pics with the bed or bumper on?
#35 |
Sorry, I don't. I'm not that far yet.
#36 |
Well, we crawled under the 66 and there's not a lot of room between the frame rails (maybe 30") and really not a lot from the last crossmember to the back, so it may be back to the drawing board....no license plate flip filler unless I can find a different tank like that Camaro tank to fit there.....
#37 |
My truck currently has an LMC rear mounted, side fill tank, #2 in this picture:
![]() I just picked up a filler neck from a '61-'63 full size Chevy car: My plan is to, after some careful measuring and other prep, bring both to a welder, have the side fill opening welded closed and this welded to the back to end up with a '69 Camaro type filler behind the license plate. I'll post the results when I finally get to it. |
#38 |
Doesn’t that end up hanging down a bit under the truck?
#39 |
![]() This is what it looks like installed, but without a bumper. I've subsequently installed a bumper, but I don't think it is correct. I'll take another picture or two the next time I have daylight to work with. |
#40 |
#41 |
Whoa! I guess no one asks ya "need a lift?"!!
#42 |
The problem that I have is only 6 inches from framerail to ground!! I believe I[ATTACH]Attachment 1338326[/ATTACH] don't have any options besides a fuel cell in the bed or under raised bed floor!
#43 |
You could get a custom one made for your dimensions.
#44 |
![]() Here is a picture with the bumper installed. I figure I will have to cut a semicircle into that rear crossmember so that the filler tube will be high enough on the tank to be able to take advantage of all 21 or so gallons of capacity. |
#45 |
#46 | |
![]() Join Date: Sep 2006
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#47 |
#48 |
I got it up that high because I trimmed my cross sill. I put temporary plywood in the bed.
#49 |
This is the Chevy van tank, not noticeably visible under the roll pan. I'm redoing the filler this winter and going with 2 inch widened tubs so it looks a little rough right now. Hope this helps. Last edited by verdell; 12-20-2014 at 08:51 PM. |
#50 | |
![]() ![]() Join Date: Jul 2002
Thread Tools | |
Display Modes | |
