#26 | |
Re: Original longbed or cut shortbed?
My buddy had a th400/203 in a 78 or so truck. One day whistling up the interstate the front shaft seized, came up through the floor on the passenger side, and landed in the seat next to him. He needed a new tranny, transfer case, and front shaft to get back on the road. Plus when it happened it was summer and he had to pull over in the middle of the interstate. On the grass. Which started on fire. The firemen simply opened the fire hose on the interior of his truck. Saved the truck but they got his Creedence. Now I doubt you'd end up catching on fire and losing all your cassettes but I guess I'm saying I'd stick with a NP205. Another thing. If you keep the truck at a long wheel base, the drive shafts you have now will work with what ever stock tranny and transfer case you want to go with. In these trucks, GM made the trans/adapter/t-case the same length by varying the length of the adapter. If you stick with stock, everything else bolts up. Including that mount from the t-case to the frame. FWIW, I switched from a manual to a th350 about 10 years ago and to this day still think that was the best update I did to my truck. I only kick myself for not having a 700r4 built to work with the adapter. No matter what stock trans you go with, the final drive out of it is 1:1. On the interstate my stock height tires and 3.73 rear end gears really make my engine turn fast.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#27 |
my opinion i like a factory honest shortbed, and 4x4 i like longbed, to use as a truck.
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
#28 | |
I gave the drive shafts with the trade.I was thinking if i do the shortbed i can just use a 1 piece drive shaft.will that work? I feel more comfortable with a standard transmission in a truck. |
#29 |
So on Friday I decided to stop thinking about it and just cut the frame.I already have the shortbed.So That’s The cheapest thing for me to do.My neighbor really helped out a lot.She just recently got into trucks and signed up on the board.She drilled and punched a lot of rivets out and did some cutting on the frame while I was cutting the boxing plates.
![]() ![]() ![]() ![]() ![]() ![]() It Started to get dark and I really needed to finish the welds on the outside of the frame so used the light. ![]() ![]() Im pretty broke so used steel I had.The boxing plates will be 2 pieces on each side. ![]() |
#30 |
#31 |
![]() Join Date: Nov 2004
Looks like you laid down some pretty nice beads, good job on the shortening! Glad to see you went with what you wanted to do.
I actually just brought my shortbed fleetside bed home I bought 6 years ago and stored at a friends house to replace my short step bed. It was a great feeling to finally have it home.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#32 | |
Thanks.The inside looks better then the outside.It was getting dark and i had a bunch of clamps in the way.
Dam that's a long time.I know the feeling.When i stored my truck at a friends for 10 days i,i was so happy when it was back home in the garage. Quote:
#33 |
I've owned and driven the truck for the past 18 years... so I guess not that long relatively
#34 |
#35 |
nm ... another good truck bites the dust. Enjoy!
#36 |
C/10 junkie
Looking good man
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#37 |
#38 |
#39 | |
Don't take my comment to mean that your opinion is wrong. I'm just saying that there are other perspectives on what a truck can be used for and which one is best for which type of use. |
#40 |
![]() Join Date: Mar 2015
Automatic transfer cases have 26 spline input shaft splines and the manual transmission has 10. The sm465's are a dime a dozen. When the truck is rusted out and the motor smoken the sm465 are still good. At the swaps I could bring home a truck load for 500 bucks. To make a real streatable truck run a 4L60. One change you would never regret. The cab is so much quieter it is hard to phantom.
#41 | |
#42 |
[QUOTE=Accelo;7096332]Automatic transfer cases have 26 spline input shaft splines and the manual transmission has 10. The sm465's are a dime a dozen. When the truck is rusted out and the motor smoken the sm465 are still good. At the swaps I could bring home a truck load for 500 bucks. To make a real streatable truck run a 4L60. One change you would never regret. The cab is so much quieter it is hard to phantom.
I like the sm465. |
#43 |
Man great job on the progress! Looking real good!
#44 |
Thanks!Maybe this will turn into a build thread...I sold the big block and got a small block.Its used.I got it from my boss.His friends used it to test run a car at el mirage.He said it went 160 mph.Anyways its a good runner.I just need parts now.I was thinking of using the 2 barrel carb and intake because i got one for free.I got the carb soaking in that dip.
what do you think about running a 2 barrel on a small block 350? ![]() Last edited by pat english; 03-21-2015 at 01:16 AM. |
#45 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice work on your truck. I had a 70 K20 with a 350 and a 2no and it ran pretty good and got good mileage. I towed my parent's 38' steel 4 horse slant trailer with it and it got 10mpg doing it. That beat the f350 with a 460 that couldn't maintain hills and got 6mpg. I think we had a 600cfm carb off a stock car my dad's friend sold us. It sure worked sweet!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#46 |
Cool build thread! What did you use to paint the frame? As mentioned, a two barrel carb will work just fine on a small block. I had a 70 nova when I was 17 and it had a factory 350 with a two barrel. That car pissed off a lot of the mustang owners haha.
#47 | |
#48 | |
On my last frame(the 2wd one) i had everything sandblasted and used some fancy chassis paint.My wife noticed that the rustolium looks just as good as the pro chassis paint.here's a pic of both frames.The top is the sand blasting and pro paint,and the bottom is clean it good enough and rustolium.What do you think? ![]() ![]() Last edited by pat english; 03-21-2015 at 10:06 AM. |
#49 |
painting is all about the prep work and then application. using fancy paint rather than spray cans won't necessarily look better if you don't put it on right.
#50 |
Thread Tools | |
Display Modes | |
