Old 02-13-2015, 03:33 PM   #26
El Dorado Jim
Re: Quadrajet or Quadra-throw out the dang window!!
Originally Posted by D.PASSMORE View Post
If you need to get the truck moving and are going to use it as a daily driver. This is your best option ^^^^.
Sometimes when I get to a point with a engine problem (timing or fuel) and can't determine the cause, I will break out the ole Edelbrock and bolt it on to see what changes occur. They are easier to tune. But, remember a Edelbrock is a square bore and a Q-jet is a spread bore. You will need a adapter plate or a square bore intake manifold.
I run edelbrock air gap manifolds and 1" spacers
El Dorado Jim is offline   Reply With Quote
Old 02-13-2015, 06:50 PM   #27
Eddie H.
Eddie H.'s Avatar
If you can find a good "virgin" Quadrajet that has never been messed with/messed up by somebody that don't know what they're doing, then rebuild it correctly, they are one of the best carburetors that has ever been built. The problem is that they haven't been produced in many years and most of the available cores are either completely worn out or butchered up beyond repair. For a daily driver, I would just get a new Edlebrock 1406 for about $300, bolt it on and go. All the ones I have ever used are extremely reliable and run fine straight out of the box.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 02-13-2015, 07:05 PM   #28
GRX
GRX's Avatar
Not to start any arguments. I understand many like them. Those Edelbrock AFB clones make me cringe.
GRX is offline   Reply With Quote
Old 02-13-2015, 08:13 PM   #29
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That makes 2 of us. Again... I know cats swear by them. But you couldn't pay me to use one.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Thread Tools
Display Modes
