#26 | |
#27 |
Re: 400 Small block engine
#28 |
I live in Arizona and have not had inherent overheating problems w/ the 400.
I built mine [ out of a 75 Jimmy]. It has gobs of torque! It will handle a 4L60e in overdrive no problem. You may try Jasper for a quality rebuilt long block. We use them for specialty engines. Good products. Mike |
#29 | |
Posted via Mobile Device Last edited by nicks diner; 04-22-2015 at 07:08 PM. |
#30 |
#31 | |
Posted via Mobile Device |
#32 |
i recently found out i have a 400 not a 450 like the po told me. before i found out i replaced the motor mounts with 350 mounts so you can use the same mounts. i live in texas and don't have over heating problems at all. also 400's have almost the same stroke and bore as a 402 big block if I'm not mistaken.
#33 |
My 406 has never over heated and its been in my nova almost 18 years now I think. The builder I got it from told me it would make torque like a big block but rev like a small block. Sounded good to me and its 435hp 515tq. He wanted more money to do a 383 and it made less hp. Im sure that's not the case now though if the blocks are hard to find. A 350 with a good set of heads and cam is probably the easiest way to go. But after doing a ls swap ill probably never do another sbc in a street truck/car again
#34 |
How did I get this OLD!
![]() Join Date: Dec 2014
I've had my 400sbc in my vette for almost 20 yrs. I love the torque.
http://67-72chevytrucks.com/vboard/a...1&d=1429844604 |
#35 |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#36 |
![]() Join Date: Nov 2001
A Donovan all aluminum Small Block block. Probably $4500-$5000 new.
They have replaceable iron sleeves for cylinders and only weighs 100lbs. http://www.donovanengineering.com/Bl...ineBlocks.html
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 04-24-2015 at 12:08 PM. |
#37 | |
#38 |
400 blocks are not that hard to find, but you do have to look listen and search. They were manufactured between 1970 and 79 possibly 80 but have been transplanted into other years. I've pd between $125 bare that will need 2 sleeves and $800 running. I knew a machine shop that had 7 400 blks two years ago.
Thread Tools | |
Display Modes | |
