Old 06-16-2015, 05:15 PM   #26
SnS C10
SnS C10's Avatar
Re: is my cab too far "gone"
How about some more info on that truck Texas 1963? How did you obtain the drop, engine, tranny? Or did you post all that somewhere else?
SnS C10 is offline   Reply With Quote
Old 06-16-2015, 08:36 PM   #27
dougf
dougf's Avatar
Nice truck! About that roof, I would give it a shot. I'm afraid you may blow holes in the metal trying to weld a patch since the metals probably thin. I have an old Sears flux core welder and use .030 for all my sheet metal repairs. I use short zaps and wait to cool to prevent war page, zap again in a few spots, etc... If I were you I would *consider* drilling all spot welds, popping the top off and taking a look before major repair. If everything looks ok you Cana do your repairs, wire wheel, clean, coat with por15 or paint, then zap the roof back on!
dougf is offline   Reply With Quote
Old 06-16-2015, 09:34 PM   #28
SnS C10
SnS C10's Avatar
So under the sealer in the drip rail there are spot welds?
Old 06-16-2015, 10:50 PM   #29
Monte's62
Yes, there are something like 100-125 of them all the way around. I have never did a re-skin, but member LT1 Burb has a good write up in his build. I don't know how to post a link to his build.. Sorry! Good luck Shaun
Monte's62 is offline   Reply With Quote
Old 06-17-2015, 10:33 AM   #30
Texas1963
Texas1963's Avatar
I put some info on the static drop thread and Im keeping the 230 L6 with 2 spd powerglide. If I come across a 292 im gonna hop it up and stick it in but im in no rush. The 230 runs and sounds awesome. 2 in straight pipe single out the back. It rapps!
Chief US Coast Guard Ret.
1963 SWB Fleetside Chevy L6 230
1962 Cadillac Coupe Deville 390
Texas1963 is offline   Reply With Quote
Old 06-18-2015, 10:07 AM   #31
Texas1963
Texas1963's Avatar
Sweet truck bro, do you have any picture of the rust you need to repair?
Here's what I'll be dealing with.
Old 06-18-2015, 12:30 PM   #32
rickoner
I think i would be looking for another cab. Aren't you it Texas? That looks worse than a lot of the ones up here. Almost everything you'd need to fix that isn't repopped so you'd have to use a donor cab anyways.
rickoner is offline   Reply With Quote
Old 06-18-2015, 12:56 PM   #33
1963c-10
1963c-10's Avatar
I agree...if the bottom half of the cab looks like the roof, I'd look for a donor cab.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-18-2015, 01:15 PM   #34
Texas1963
Texas1963's Avatar
You would think that, but the rest of the cab is solid. It sat for 8 years under a tree and was covered in green moss when bought it over a month ago from a buddy.
Old 06-18-2015, 01:30 PM   #35
awbrown
some careful cutting and you can put the whole roof on ,just cutting across the windshield posts and across the rear window .... I have seen it done , just have to measure real carefully ....
awbrown is offline   Reply With Quote
Old 06-18-2015, 01:35 PM   #36
1963c-10
1963c-10's Avatar
If the bottom is solid, then a roof swap would be the way to go if you can handle the welding aspect of it.
Old 06-18-2015, 01:51 PM   #37
canadian_diesel1964
Man that's a dream cab in Canada!
canadian_diesel1964 is offline   Reply With Quote
Old 06-18-2015, 02:25 PM   #38
Texas1963
Texas1963's Avatar
I'm not the best welder but I have mad gridding skills! LOL
Old 06-18-2015, 02:48 PM   #39
SnS C10
SnS C10's Avatar
Well I ended up cutting out the worst rust there is. There are some other rust issues around where I cut this section out but am going to address them later as this is the worst one. I also made a replacement piece.
Old 06-19-2015, 06:07 AM   #40
Drak993
I am with Texas 1963. Clean it up best you can . roloc disc are very good at difficult areas . Rust Bullet is the newest rust preventative paint . Application is like Por-15 was 20 years ago. You can paint and bondo right over it. I always use fiberglass reinforced filler for first coat because it is waterproof . less chance of any future problems.
Drak993 is offline   Reply With Quote
Old 06-19-2015, 08:01 PM   #41
dougf
dougf's Avatar
Agree with above, repair what you can, coat what you can't get to, filler, drive, enjoy.
Old 06-19-2015, 08:25 PM   #42
canadian_diesel1964
Fibreglass is great too!
Thread Tools
Display Modes
