Old 09-11-2015, 10:10 AM   #26
Isaiah92260
Isaiah92260's Avatar
Re: Thermostat procedure help
Finallyy got a universal fan shroud for my Aluminum Radiator, and wtf.... I'm thinking that I may of done something wrong, or.... Usually in the morning my truck runs at around 165ish-175... When i was driving to work today, it was running at 180 and at idle it went up to 195, and I have a 180 TStat.im so frustrated. I'm not sure what to do, I'm not sure if I ruined my radiator by pushing those threaded plastic ties threw the cooling fins, because some of them got damaged, but I'm sure thAts the only way they are supposed to be installed, pleased help!
I hope some of you guys that were helping on here before can help me...
Isaiah92260 is offline   Reply With Quote
Old 09-11-2015, 10:58 AM   #27
TJ's Chevy
TJ's Chevy's Avatar
It already seems like its running cooler....idled at 195 vs over 200 from last time....so I'm not seeing the issue. Let it idle during one of your 100+ days and see what happens.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-11-2015, 11:31 AM   #28
blown240
blown240's Avatar
If you have a 180 t-stat, it should warm up to at least that before the Tstat opens. So your days off running at 165 are probably over. Now, it may dip down to that once the Tstat opens, but then it will come back up.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 09-11-2015, 01:55 PM   #29
siggyfreud
siggyfreud's Avatar
Nothing seems off with your temps so far. You don't want an engine too cool. Nothing wrong with it getting up to 195-205 range. Ultimately an engine is going to heat to what it heats to, despite the thermostat. A lower thermostat won't ultimately make an engine run cooler, it will just open the coolant passages sooner. After that, it's up to the fan, radiator, and water pump to do it's thing.
siggyfreud is offline   Reply With Quote
Old 09-11-2015, 02:34 PM   #30
rcnutt
rcnutt's Avatar
Yep....those temps are fine....drive and enjoy it
rcnutt is offline   Reply With Quote
Thread Tools
Display Modes
