Old 01-04-2016, 11:31 AM   #26
midniteblues
midniteblues's Avatar
Re: Need your advice guys! Can't bleed brakes Help
sounds like your rear rubber line may have collapsed.
you could try to disconnect it an see if you get juice. but if you broke one line you may break that one also. use plenty of lube.
power breaks dont really play a part when bleeding except the lenght of the rod.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 01-13-2016, 08:43 PM   #27
jmillsUT28
Update: replaced the brake booster, all brake lines and rubber lines, master cylinder (same as the one I started with which is new), new proportioning valve, calipers, brake cylinders and shoes.
Outcome... still do not have breaks. I am thinking I might have a problem with the new master cylinder. When I am trying to bleed the right rear brake I get a jet of fluid that comes up from the little pin hole in the front section of the master cylinder. So if I have it topped off it over flows a little. It should not be doing this correct?
jmillsUT28 is offline   Reply With Quote
Old 01-14-2016, 10:57 AM   #28
midniteblues
sure sounds like one of two things push rod or master. heres a bump for ya.
Old 01-14-2016, 11:29 AM   #29
jmillsUT28
Thanks I double checked the push rod last night. I turned it out just far enough so it does not put the master cylinder in when installing it. This is the correct way to adjust it right?
Old 01-14-2016, 01:24 PM   #30
RichardJ
You need a few thousands clearance between the pin and the bottom of the hole in the MC piston. Too much clearance will increase the brake pedal free-play. Too little clearance can cause the brakes to drag or even not release at all.
Pin check/adjustment and free-play on the other side of the booster should have been checked before you even started to bleed the brakes.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-14-2016, 02:13 PM   #31
jmillsUT28
The pin has been adjusted correctly. I am thinking it might be a bad master cylinder. Going to be gone for a few days but when I get back next week will bleed a new MC and install it to see if that fixes my problem.
Old 01-17-2016, 01:56 PM   #32
dibbleg
Sorry for the thread hijack, but I've really been having a lot of the same problems with my 67.
4 wheel drums. Replaced all lines(stainless) , hoses and hardware(wheel cyls, shoes,springs, etc) . New master..getting fluid but hardly any pressure on pedal. replaced mc. better pedal but still spongy. thought i would need to maybe readjust the shoes or maybe the pushrod? i'm stumped and insanely frustrated.
Again, sorry for the hijack.. i'll make a new thread if it helps.. everything sounded like the crap i was going through.
Chris Mead Tattoos
dibbleg is offline   Reply With Quote
Old 01-21-2016, 01:48 PM   #33
jmillsUT28
I have BRAKES!!! Man this was a pain in the butt. But now I have a completely new brake system. I decided to buy a master cylinder bleeding kit that comes with the two hoses. The cheap two plug kit that comes with the MC did not work. So I bled the MC with this new kit and it fixed my problems. Thanks to all for all of the help!
Old 01-21-2016, 01:51 PM   #34
dibbleg
I wonder then if I just didn't bleed the mc properly. It would be worth it to try again I think. Might have some trapped air in there. I did use the plugs last time I tried it.
Chris Mead Tattoos
Thread Tools
Display Modes
