Old 02-08-2016, 06:10 PM   #26
WOLFMANmike
WOLFMANmike's Avatar
Re: has anyone used this setup before ?
Originally Posted by jtrichard View Post
" and even since day 1 brakes haven't been great" ....I bet .... What want to be rocket scientist installed that mess ......Not only is it plumbed WRONG but that looks like a disc/drum master to me.... Can you get a pic where the booster bolts up to see how they butchered that up?
This is the best I could do to show the booster mounted to the fire wall you asked for
WOLFMANmike is offline   Reply With Quote
Old 02-08-2016, 06:31 PM   #27
jtrichard
can you see what the bolts look like on the inside?
It could be a PB9002 universal booster
jtrichard is offline   Reply With Quote
Old 02-08-2016, 06:37 PM   #28
WOLFMANmike
Sure let me try
Old 02-08-2016, 06:49 PM   #29
jtrichard
http://www.ebay.com/itm/Universal-9-...ZUWA0f&vxp=mtr
and the master that should match up http://www.ebay.com/itm/141880767708...84.m1436.l2649
Old 02-08-2016, 06:52 PM   #30
WOLFMANmike
Best I could get is this lol
Old 02-08-2016, 07:02 PM   #31
WOLFMANmike
The brake push rod travels 1/4 what the pedal travels 4:1
Wolfman if the booster is mounted good then i would just get the correct master and re-plumb the lines ... have to figure out what the booster is (any numbers on it?) so you can get a rebuilt... you might drive by a good old parts store and see if anyone there cant figure out what it is off of ....i found some pics that look like yours have not been able to ID it yet
The booster is leaking so it needs a new one but if I do that I need a welder and I don't have access to a welder ... what I found out about it seems to be a 1985 bronco II
Old 02-08-2016, 07:14 PM   #32
WOLFMANmike
Don't want to get off topic to much but I thought ide show you some other crap the PO did to my poor truck ... I fixed the butcher job on the stereo spot ... again I have no welder so I'm gonna do the best I can with what I have to fill in holes ... I was gonna start a build thread but I'm no mechanic and the stuff I would be doing would never be as good as others on here .
Old 02-08-2016, 07:33 PM   #33
jtrichard
looks like your right about the broncoII also looks like some of the mustang
with the booster and master above http://www.ebay.com/itm/CFR-6-HEIM-J...37kW4Q&vxp=mtr
http://www.ebay.com/itm/LC-03802401-...IAAOSwFMZWtOXT
this would be better looks like http://www.ebay.com/itm/U51067-037-1...cAAOSwvUlWq~wp
http://www.ebay.com/itm/250421BG-Rod...YAAOSwGotWrFzv
http://www.ebay.com/itm/NEW-USA-MADE...kAAOSwJcZWcDhj
few things that you could use to make up the rod
http://www.ebay.com/itm/NUT-3-8-24-t...FSxuNh&vxp=mtr
Old 02-08-2016, 07:41 PM   #34
The Rocknrod
Moderator
The Rocknrod's Avatar
Thread Tools
Display Modes
