Old 05-17-2016, 04:35 PM   #26
TwoFiftyShifter
Re: How rare is a factory manual trans?
I have 3.08 gears so I take off in 1st when uphill, and sometimes on flat ground. I can still take off in 2nd anywhere though because I'm halfway decent with the clutch.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 05-17-2016, 05:58 PM   #27
Tom
driving is in my blood
Tom's Avatar
Originally Posted by MikeB View Post
Do you guys typically start off in 1st gear with the SM465? Seems like it would be done in less than 50 feet.
If by 1st you mean compound low gear, no, people don't do that. 1st gear [what I think your reffering to as 2nd out of 4 total] is the same ratio as a normal trans 1st gear, no reason not to use it regardless of rear end ratio unless your towing large weight.
Old 05-17-2016, 11:21 PM   #28
cheepin
My 77 suburban,88 crew cab I had were both 465/205s. My current 84 crew is 465/205 and the 87 Suburban we just stripped was 465/208. My 87 suburban is th400. Along with the 79 and 86 Subs I had.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 05-17-2016, 11:34 PM   #29
Jrgunn5150
All of mine were labeled L-1-2-3
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 05-17-2016, 11:50 PM   #30
bL.A.zer90045
i have 4 sets of manual pedal set-ups,as well as 3 sm465's....
bL.A.zer90045 is offline   Reply With Quote
Old 05-18-2016, 06:14 AM   #31
D13
D13's Avatar
77 is 3 on the tree tree light duty
81 is 3OTT HD
2wd aluminum case hydro clutch A833 sitting in shed, next to
4wd iron case A833
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 05-18-2016, 06:35 AM   #32
Keith Seymore
Keith Seymore's Avatar
Yes - I think technically it is considered a three speed with a creeper gear.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-18-2016, 06:36 AM   #33
TwoFiftyShifter
People do! I just like rowing the extra gear maybe...
1982 K10 SWB
Old 05-18-2016, 01:17 PM   #34
1976gmc20
No - virtually never!
Unless starting on a steep hill or pulling some awful load, or on some rough road where you need to go slow (my C20 can go most places that the 4x4's go).
Heck, with the engine warmed up I hardly go 50 feet when starting out it second gear, before shifting to third.
Depends on the axle ratio(s) of course - I had a K10 that had race car gears for gas mileage
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 05-18-2016, 01:31 PM   #35
MalibuSSwagon
Yes I use the Low gear when hauling a load, such as when I was towing cars this weekend. Engagement is much smoother when you have 6000lbs attached to the truck otherwise in daily driving I don't use it much if at all.
MalibuSSwagon is offline   Reply With Quote
Thread Tools
Display Modes
