06-23-2016, 04:39 PM | #26 |
Re: Can I add a pusher fan to stock set-up?
I do. I am going to have to find the right spacer, it is cheaper to try that first.
06-23-2016, 05:36 PM | #27 | ||
20' Daredevil (Ret)
Yours may be different if non-stock parts have been swapped in.
06-24-2016, 09:41 AM | #28 |
Ok, I think I tried that and the bolts were too long, then bought shorter bolts that were too short =) Will look at it again.
06-24-2016, 10:24 AM | #29 |
Old member
This is how you want a stock clutch fan to look in the stock shroud.
06-24-2016, 02:28 PM | #30 |
20' Daredevil (Ret)
Perfect, Andy, just perfect!! Picture worth a thousand words....
06-24-2016, 03:50 PM | #31 |
Old member
That setup work perfect for about 20 years in my truck. I never once had a over heating issue with it.
06-26-2016, 10:32 AM | #32 |
Good Advice, am working on it this morning. Thanks.
07-02-2016, 11:47 PM | #33 |
20' Daredevil (Ret)
Any follow-up on this?
07-03-2016, 01:46 AM | #34 |
Another idea. You said you put a" new long nose water pump on. Is that why the fan is so close to the Rad.?
Thread Tools | |
Display Modes | |
