Old 03-13-2017, 09:02 AM   #26
69-72
69-72's Avatar
Re: Has anyone improved ride/handling in Jimmy/Blazer?
Is there a way to add a front sway bar without swapping out the front crossmember?
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 03-13-2017, 10:03 AM   #27
60case
I added a sway bar from a 1986 k20. I made these plates out of 1/4 steel. Works good. Uses stock cross member
60case is offline   Reply With Quote
Old 03-13-2017, 09:02 PM   #28
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Can you post more pictures of how this connects?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-13-2017, 09:34 PM   #29
68c10airstream
68c10airstream's Avatar
I read through all of the posts an i'll add this idea! Add a plastic leaf spring liner designed to reduce inner leaf friction. I re-sprung my 48 willy's pickup after the stock 7 stack narrow set flattened out from a sbc v8. I did this the same time i put a scout disc brake front end under neath it and a ford axle out back and did the same re spring job in the rear. It made a world of difference with fewer leafs (4 i think) and reduced inner leaf friction was awesome!!
68c10airstream is offline   Reply With Quote
Old 03-14-2017, 12:42 AM   #30
Madtrucker
I've heard it's dangerous to have a front sway bar without a rear. If that's true, which seems to make sense make sure you do the rear first.
1968 k10 lwb-swb stepside
1936 chevy truck
1977 corvette
My 68 lwb-swb 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=527176
1972/68 blazer 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=641824
Madtrucker is offline   Reply With Quote
Old 03-14-2017, 12:04 PM   #31
60case
GM made millions of cars and trucks with front sway bar and no rears. I used a piece of steel 8x2x1/4 to make the brace for the bar mounting brackets. the spring top plates are from the 86 K20 the bar came from
Old 03-14-2017, 12:41 PM   #32
Coatingguy
Quick question on this subject,
Does anyone have the part number for the Redhead steering box that would fit a 1972 gmc jimmy 4x4? I'm only seeing boxes for 2wd applications on their website.
Coatingguy is offline   Reply With Quote
Old 03-14-2017, 03:21 PM   #33
GMC-YA68
GMC-YA68's Avatar
Part #2851 was the part number a year or so ago - you'll need to tell them if you want 15:1 or 18:1.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 03-14-2017, 06:19 PM   #34
71meangreenc10
Thanks for the pics, never seen this setup with the bar connecting to the axle before. Interesting...
Time to go square body hunting....
Smitty
71 C30 Wrecker
Thread Tools
Display Modes
