#26 |
Re: Just Quoted $800 For Plugs & Plug Wires
If someone told me $800 to replace plug wires and plugs I think they'd be laid out of the floor before I knew what I did. Did he have a gun on you? I'd take that quote as attempted robbery. I'd be thinking twice about how much business I'd do in the future. Are you sure you haven't been ripped off in the past by them? I find the shops that charge the higher amounts do the crappiest work. I just changed my plugs and wires. Took about an hour and parts were under $100...using Taylor 8mm wires. I have Hedman Torq-Steps and run the wires up. I ask for '75 Vette wires because they were run over the valve covers and had HEI.
#27 |
Give us a sample of the other work he has done for you..
#28 | |
Maybe this shop makes more money on other jobs and doesn't like to do smaller jobs like this? Either way, don't be offended. Do the work yourself. You'll learn from it, and take more pride in your truck than having someone else work on it.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
#29 |
![]() Join Date: Feb 2009
That's only $650 an hour, on the assumption the wires and plugs are VERY GOOD. Like others said, they don't want to do it. More than that, it was their clue it's a simple task you can do yourself. They'd have been more forthcoming to have just said so.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#30 | |
Spot on. The only thing I'll add is the ratcheting crimpers thing. I got the ACCEL 170036 Wire Crimp Tool from Amazon for $67.99. It's one of those things that you could go your whole life without but when you do finally get one, you'll wonder if you could ever live without it again (kind of like an air compressor). Also, with one of these and most other crimpers, they cut the perfect length and strip the wire cleanly (No need for utility knife and dykes). |
#31 |
![]() Join Date: Aug 2009
Thanks for all of the pep talks, guys. 👍🏻
I ended up ordering: Taylor Universal-Fit 9mm FirePower Ignition Wire Sets 92051, MSD Pro-Crimp Tool II 35051, and (2) MSD Iridium Spark Plugs 37204 from Summit. Arriving on Wednesday. I'm an HVAC contractor with over 20 yrs exp. I'm good with my hands, and a problem solver. If I can't figure this out... |
#32 |
I don't think this was a case of a guy pricing high because he didn't want the job. Why wouldn't he? It's a gravy job and a real money maker at 1/4 that price. I'm a contractor and if I'm plenty busy I bit higher, or at least with great confidence. But, if I'm too busy to do the job, money has nothing to do with it. I just tell people I'm too busy right now, either wait for me or find someone else. I often still get their work later by being honest.
You'll be back here showing pictures of a job better than Million Dollar Mechanic would have done talking about how easy it was...and how good you feel about the job you did.
#33 | |
I think you're right, Tim. Thanks for the encouragement. FWIW, the shop gave me a rough estimate of $800 for the labor on a rear end gear swap, and $1000 for the labor on a T350 to 2004R conversion. ¯\_(ツ)_/¯ |
#34 |
For $800 that should include a jar of Vaseline.
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
#35 |
Who Changed This?
![]() Join Date: Jan 2013
55 gallon drum.
Man, this place needs a "like" button!
#36 | |
![]() Join Date: Dec 2013
#37 |
I actually didn't think that the estimate for the transmission swap was excessive, and figured the labor on the rear gear swap was about par for course in Southern California. If I'm wrong, and a reputable shop will do those jobs (well) for less than that, I'll be a happy man.
#38 |
These other prices don't seem out of this world like the plug wires, considering your location. They must have just gotten done a plug wire job on some exotic that required removing half the engine compartment after quoting a couple hundred dollars.
#39 |
That really is what I was thinking. But they've been working on American classics for well over half a century, so it's still a head scratcher. I wonder if they just rely on the mechanics to quote the jobs, and I ended up with the youngest guy.
#40 | |
It takes about me about an hour to R&R a transmission on a lift with a trans jack, and I'm slow. That leaves about 10 hours to hook up the TV cable. If they're being very diligent, they'd pull the pan and check the plunger depth on their final TV setting, but there's really not much else to that swap.
#41 | |
![]() Quote:
#42 |
![]() Join Date: May 2012
It has nothing to do with Orange County. The guy is just a rip... Period. Go elsewhere. He said $800 ... Translation.... "Go away, we don't need your business!"
White K20 |
#43 |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
Photobucket Auto repair?
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
#44 |
I think the person who gave the quote saw that cash '68 and the numbers started rolling in his head like a slot machine
![]() I don't know how the shop is set up. If they have a service writer or any one of the wrenches that can stops to help or the bosses son just got started and doesn't know poop from Shinola. I wouldn't write them off if you've been satisfied up till this and you know no other place better. Just see what they quote next time and go from there. If they recognize you as a repeat customer, they may recall they the job they lost due to a high quote. Often, a place gets to be known as the shop to take the old stuff to get treated right and they feel they can charge a premium. If that's the case, maybe there is some place better. Ask around before you need something else. The fact is, this old stuff is easier to work on than what most mechanics see everyday, so really should cost less to have worked on. I didn't get into mechanics because I hate working on newer stuff. If I could only work on old stuff I'm ready for work! I'd think it would be a pleasant break for a wrench to have an oldie in their bay.
#45 |
This brings up something I think we should have... A sticky for shop estimates to get advice on whether we are getting ripped off if we are not doing all of the work ourselves. While I would love to do all the work, I barely have a moment to breathe, even on the weekends so many times I have to have someone else do the work if it is ever going to get done or is urgent to keep the vehicle on the road.
#46 |
Sound advice as always Tim.👍🏻
#47 |
Thread Tools | |
Display Modes | |
