02-21-2019, 10:07 PM | #26 | |
Re: Drive shaft support bearing breaking.
I'm way late to this discussion, but i've experienced a similar problem. recently acquired a 68 shortened c10. the cb broke on me then the second one broke after about 50 miles. I just finished installing the heavy duty cb and the slip shaft sold by cj pony parts. Pretty much the same setup in this post. Looks like it should do the trick. fingers crossed! |
02-21-2019, 10:31 PM | #27 |
nope , 1 piece drive shaft . if your running a auto trans no need for slip yoke in shaft. get wedge shim kit to correct pinion angle
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 02-21-2019 at 10:37 PM. |
02-21-2019, 11:03 PM | #28 |
02-22-2019, 02:21 PM | #29 |
Post Whore
I've got 8000 trouble free miles on the new setup in my daily driver Burban.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-22-2019, 08:20 PM | #30 |
02-23-2019, 10:44 PM | #31 |
The panhard bar is a give away. If I remember right with leaf springs there is an alingment pin in the center of the leaf where the axle perch sits on to aline. Im just wondering if they welded on leaf spring perches without checking the pinion angle.
I did away with that style drive shaft and bearing on my longbed 1/2 ton. I used a complete 3/4 ton set up after having driveshaft shortened and balanced. I did have to use an adaptor ujoint at the rear end, since a 3/4 ton uses a dana 60 larger pinion. |
Thread Tools | |
Display Modes | |
