Old 01-14-2019, 11:14 PM   #26
Old school57
Junior Member
Originally Posted by 68 P.O.S. View Post
The original dealership option put it on the rad support right above the horn. Might be a good place to swap yours to so it's out of the way. Just need longer hose to run it under the shroud.
Old school57 is offline   Reply With Quote
Old 01-14-2019, 11:15 PM   #27
Old school57
Junior Member
Old 01-14-2019, 11:22 PM   #28
Old school57
Junior Member
Hey since you have a recovery tank mabey you could steer me in the right direction as far as radeator cap that will work & where I might find one
Old 01-14-2019, 11:37 PM   #29
Old school57
Junior Member
Re: Relocating coolant overflow
Hey since you have recovery tank how can I get the right radiator cap I have posted today with no luck Old school57
Old 01-15-2019, 12:02 AM   #30
Old school57
Junior Member
Where do you guys get your closed system radiator caps
Old 01-15-2019, 02:22 AM   #31
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Very common item, any auto parts store should have them. Got mine at my local NAPA store.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-30-2019, 03:09 PM   #32
EagleChief
EagleChief's Avatar
Going to revive this old thread... I'm looking for some new ideas to mount my overflow. Several great options on here. Are you guys just using self-tapping screws to mount these?
As previously asked, I'm having an issue finding the right cap to make it work. I've tried 2 caps, and neither one of them work. I even went to the local parts store and they couldn't tell me the difference in radiator caps - mainly cause he couldn't look it up on his computer.
Anyone have a part number for the cap I need?
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 07-30-2019, 04:28 PM   #33
HO455
Post Whore
HO455's Avatar
Virtually every car since the seventies has had a over flow tank and an appropriate radiator cap. The only real difference in the caps would be the pressure rating of the cap until you get into the late model small caps.
Can you post pictures of your system and describe in more detail what problem you are experiencing.
RIP Bob Parks.
Old 07-30-2019, 06:56 PM   #34
72longstepper
Bought this for my build------------
https://www.ebay.com/itm/3-x-10-POLI...72.m2749.l2649
72longstepper is offline   Reply With Quote
Old 07-31-2019, 11:08 AM   #35
EagleChief
EagleChief's Avatar
I'll try and get some pictures this evening, but my truck did not have an overflow tank. I just added a generic one from Advanced Auto a couple of months ago, as a temporary test on my coolant system. When I bought the truck, it was losing a lot of coolant with no visible leaks. So, I added a reservoir just to see if I could catch any in there. It's gradually collected more and more as the outdoor temps have gone up. Now, I'm catching quite a bit in the reservoir, but it won't pull it back in to the radiator.
I'm going to use a different container, and find a better location that is more permanent once I can figure out what's going on.
Old 07-31-2019, 12:34 PM   #36
rpmerf
rpmerf's Avatar
Bottle is from an 00's Acura MDX. I had to bend, cut, and weld the bracket a bit to get it to fit. I drilled holes in the fender, and welded the nuts to the bracket, so I can easily bolt it in from underneath.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 07-31-2019, 10:29 PM   #37
wpavlis
I went with the full custom one from autozone.
wpavlis is offline   Reply With Quote
Old 08-01-2019, 12:46 AM   #38
EagleChief
EagleChief's Avatar
Here are a few pictures of what I'm currently using for my setup. Like I said, this is temporary until I can get any issues figured out. I think my permanent mounting will be on the driver's side of the radiator.
But, so far, I can't get the radiator to pull any coolant back from the overflow container.
Photo 1: current set-up.
Photo 2 & 3: first cap I tried.
Photo 4 & 5: second cap to try.
Old 08-01-2019, 08:03 AM   #39
rpmerf
rpmerf's Avatar
When the coolant is hot, it expands and pushes past the cap into the overflow reservoir.
When it is cool, it contracts, creating a vacuum, which pulls coolant in from the reservoir.
If there is a leak, when the coolant is cooling down, it could pull air form the leak rather than the overflow.
Leaks can be hard to find, as they can be very small, but over time lead to a lot of coolant loss. You can get dye for the coolant to help find leaks.
Couple thoughts. Is the top hose hard when the engine is running and hot? After turning off the engine, how long does it take to loose pressure?
1997 GMC Suburban
Old 08-01-2019, 12:25 PM   #40
HO455
Post Whore
HO455's Avatar
With the current set up what is the coolant level in the radiator after driving and cooling off?
RIP Bob Parks.
Old 08-01-2019, 12:45 PM   #41
EagleChief
EagleChief's Avatar
I'm not sure how long it takes for it to lose pressure. It seems like it has lost the pressure the next day. But, I've only squeezed the top radiator hose once or twice, after a cool down. I've never religiously gone out to check it at different intervals to see what's going on. Haven't had the chance/time to do it.
I just switched the cap and only drove it a short distance with that cap on it. So, I don't have a good trial run with this cap, yet.
I'm going to dump the reservoir again to refill the radiator. More than likely going to go to a cruise on Saturday night that is about an hour away. That will give me a good chance to get everything hot and then let it cool, then get hot again on the way home.
Old 09-27-2019, 03:29 PM   #42
68 TT
Still plays with trucks
68 TT's Avatar
Another option I have been considering is the 4th gen Camaro coolant recovery tank. In them it is integrated with the battery hold down tray but I think there is enough room to tuck it in below our battery tray and still reach the filler neck. They hang kind of low but there may be enough space to work with. Have to grab a used one to test fit and see.
The pictures are of people retrofitting them into 3rd gen Camaros.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-27-2019, 04:08 PM   #43
tim_mc
tim_mc's Avatar
I'm happy with my Astro van overflow tank - installed only a week or so ago. I need to replace the Champion radiator cap with one that will siphon. The tank is deceiving and is larger than it looks. I like that it uses space in the front corner that would otherwise go unused. The single hex screw bolted to the corner brace keeps it secure.
For anyone interested, it's Chevrolet Astro GMC Safari 85-94 Partslink GM3014101, OE P/N 15594487.
~Tim
tim_mc is offline   Reply With Quote
Old 09-30-2019, 08:09 AM   #44
EagleChief
EagleChief's Avatar
Got my radiator to finally work and siphon the fluid back from the overflow bottle. Went ahead and bought another new cap and all is good. Ended up mounting my bottle on the driver side of the radiator mount. Don't have any pictures, but there are a few on here.
Thread Tools
Display Modes
