03-07-2019, 08:21 PM | #26 | |
Re: 1972 GMC frame and stuff
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 03-07-2019 at 08:22 PM. Reason: more |
03-09-2019, 12:48 AM | #27 |
Drewbee
I will take them. ******* (Getter-done - $50 + shipping for all of what you asked so cab mounts and bed mounts.)******* I will PM info for shipping Thanks
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
03-11-2019, 03:03 PM | #28 |
Thanks Getter-done! Let me get finish getting them off. These things are a booger, I’ve grinded the top of the rivet heads but the rivets don’t want to let go! Nothings easy in life ha! As soon as I get them off I’ll follow up with you on shipping.
03-11-2019, 03:33 PM | #29 |
Piece of advice. Grind the head flush before hitting it even once. Then a blunt punch or even an old bolt. Then knock the hell out of the rivets. Sometimes easier to pry the bracket or whatever your removing and it’ll pull the rivet thru
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
03-16-2019, 11:25 AM | #30 |
Thanks Madkidd that’s what I did with my 4x4 frame and it worked great. These are laughing at me. I’ve grinded all the heads down but the rivets are swaged in the frame tighter than a gnats arse. Just have to remove one more side.
03-16-2019, 11:59 AM | #31 |
I Feel ya. I pulled body brackets, leaf hangers, shock mounts, exhaust hanger off two rails last night
03-16-2019, 11:30 PM | #32 |
I would be interested in the rear upper shock mounts that are riveted to the frame.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
03-16-2019, 11:49 PM | #33 |
How much for both front spring hangers shipped to London ky 40741?
03-16-2019, 11:53 PM | #34 |
Im also looking for the pass upper shock mount, if the previous post doesnt take them.
03-17-2019, 02:20 PM | #35 |
AllChevy - $40 plus shipping for the shock mounts
Carls did you mean the rear spring hangers? This truck is 2wd and only has leafs in the rear. |
03-17-2019, 02:49 PM | #36 |
I’m interested in all four wheels for sure. I know shipping is going to be crazy but what are you asking for them?
03-17-2019, 02:51 PM | #37 |
Sorry disregard, I got excited and thought that they were 6 bolt.
03-17-2019, 06:52 PM | #38 |
03-17-2019, 06:54 PM | #39 |
03-17-2019, 06:58 PM | #40 |
03-17-2019, 07:16 PM | #41 |
Sorry, I meant to say I need front leaf spring hangers for the rear leaf springs. I was trying to reply to your post and my sister in laws bulldog was wanting to play.
03-17-2019, 10:20 PM | #42 |
Sorry Drewbee, I guess I'm looking for mounts off a 4WD. Yours appear to be riveted with two on top of frame and one on the bottom of frame. The 4WD mounts have two on top and the bottom rivet goes through the side of the frame. Thanks
03-17-2019, 11:23 PM | #43 |
Actually 4wd will still have the four on the side and two on the bottom also. But put some on mine off a 72 blazer. Also when you’re looking for hangers the 4wd springs spacing is narrower that c10 and c20. I’m unsure if 67-70 4wd hung below the frame or not
03-18-2019, 08:38 PM | #44 |
Are the exhaust brackets still available?
03-18-2019, 09:30 PM | #45 |
I'm looking for the rear upper shock mounts not hangers. I want to install them on my 1964 C30 dually which has no rear shock mounts. Mounts off my 1972 K2500 will fit the 64.
03-19-2019, 09:07 PM | #46 |
Eagle - Madkidd has dibs on exhaust brackets. I’m trying to get to it, unfortunately I’m the only man in my department so it’s been a lot of OT. However I ain’t complaining about the extra money. Cha-ching! 😀
06-20-2019, 08:24 PM | #47 |
Payment sent
06-20-2019, 09:06 PM | #48 |
06-28-2019, 07:29 PM | #49 |
Received Brackets.
Thanks for your time and effort. They will be put to good use. .
06-28-2019, 09:17 PM | #50 |
How much for the pass side frame shock mount?
Thread Tools | |
Display Modes | |
