Old 01-21-2004, 10:43 PM   #26
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Originally posted by yellow72custom
LOL! My rear is howling.....If only i could stuff a chiquita through the fill hole
Maybe this guy could help ya out???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-21-2004, 10:48 PM   #27
Clancy68
[i]
I know aspirin has an acidic base, so it could help refresh/recharge the battery acid. It would not be near as strong as the sulfuric acid though. [/B]
acidic base? Ph scale goes from 1-14 acids are at one end(1-7), and bases are at another(7-14). stuff like water is in the middle. at 7. did i misunderstand?
--Scott
Clancy68 is offline   Reply With Quote
Old 01-21-2004, 10:52 PM   #28
CG
BlahBlahBlah
this is all confusing...so i can drink battery water if i have a headache and when my stomach starts making noise i eat a banana peel with a sawdust chaser?
Old 01-21-2004, 11:23 PM   #29
Locutus
Locutus's Avatar
Asprin is acetylsalicylic acid. I assume that by adding it to the battery it might help increase the level of acid thereby extending the life, but if that is true wouldn't muriatic acid(HCl) be better as it is much stronger than asprin.
Mike
Locutus is offline   Reply With Quote
Old 01-21-2004, 11:46 PM   #30
Spoof
Spoof's Avatar
The old sawdust in the differential trick is alluded too in John Steinbeck's Grapes of Wrath, so that tricks been around awhile fer sure.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 01-22-2004, 01:23 AM   #31
djracer
djracer's Avatar
I would never put saw dust in anything but maybe a demolition car but I worked at a parts store and delivered parts in an old elcamino that was slip shifting bad and we put in k&w trans fix and I drove the crap out of that thing for a couple more years!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-22-2004, 01:29 AM   #32
Kenneth Brown
The comet thing was actually a GM service directive on the first small blocks. The ring hatchmarks were not seating with the rings. GM reccommended to pour it down the carb. The motors were using a quart of oil every 500 miles.
Kenneth Brown is offline   Reply With Quote
Old 01-22-2004, 02:42 AM   #33
Hooter
My other Love
Hooter's Avatar
How bout rice to knock off carbon, talk about as real rice burner
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-22-2004, 07:52 AM   #34
Lippyp
English Chevy Owner
Lippyp's Avatar
I would imagine that the aspirin helps remove the sulphatesfrom the plates in the battery which is what stops it charging properly. I know you used to be able to buy a compound to chuck in an old battery thet revived it, sadly they seem to have stopped selling it now.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-22-2004, 03:38 PM   #35
Rooster's 67
Rooster's 67's Avatar
you could also use a bowl of oatmeal to quite domn them noisy rears and manual transmissions. just don't plan on goin' too far. Ive heard of the peels of the bannana being used, which is cool because after your monkey is done you just have the peel...lol
also heard of 80-90 gear oil being put in crankcase to quieten down noisy bearings.....done that one lasted about 500 miles....stinks like he!!.
the only true Fix is to fix the worn parts, and you dont run the risk of tearing up more than what was originaly damaged.
You can use at your own descretion(sp?) a fine spay bottle mist into the carb of an engine running at 1500RPM or so to remove carbon. but the water expands greatly under combustion and you run the risk of damaging bearings. but it will clean the carbon out. you can use this theory to check for blown head gasket, by pulling the plugs and looking for the plug that has the cleanest ceramic near the electrode. That will be the cylinder with the blown gasket, course the ground electrode may have rust on it too.
You can use auto trans fluid up to %20 of the crankcase oil mix to remove sludge build up also, the detergent in the fluid will help break it up. but be sure to shorten the oil change intervals(can clog filter)
All above info should be used/not used at the readers own risk, I will not be held liable for any damage occuring to property or personal self.............whew
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-22-2004, 03:45 PM   #36
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
The last thing you want to do is use the proper fluid replacement for anything! LOL
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Thread Tools
Display Modes
