02-05-2004, 04:16 AM | #26 |
I would consider a demon carb over holley, the demons just look tougher to me. But they seem to be just a holley with a cool looking face lift with billet baseplates and billet metering blocks. and they actually a bowl site glass you can actually see the gas through, plus they come with a metal dual fuel line kit with a place for a fuel pressure gauge. the holley street avenger i bought said dual fuel line kit included. I was somewhat disapointed when i opened the box and found a couple of peices of rubber hose, some plastic connector fittings and some clamps for what i paid for the carb. If you don't care about the having the hotrod appearance when you pop the hood, get a quadrajet. I just like holleys and demons cause I like the hotrod look under the hood, although i will have to admit prob not the best choice for daily driver and economy. but as previously said, no matter what carb you get a little tuning will go a long way.
02-05-2004, 09:42 AM | #27 |
With all this tuning talk How do you properly tune your carb?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
02-05-2004, 09:35 PM | #28 |
Mike, I've heard the 'QuadraJunk' nametag before & I would tend to agree w/you. But..... we all know original 'Quadra-Jets' are more commomly (and accurrately) referred to as 'Quadra-Bogs' because of the vacuum leaks associated w/worn throttle shafts.
New carbs rule, irreguardless of manufacturer..... when properly tuned.
02-05-2004, 10:23 PM | #29 |
Professional Grade
Thats where a good old rebuild kit comes in handy I'm putting my Carter Q-Jet onto my engine when I'm done with it
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
02-06-2004, 12:22 AM | #30 |
Under construction!
I would recommend a Quadrajet or Edelbrock 1406. My El Camino had a GM crate motor w/ a 1406 and it performed awesome.
Or you could install a TPI setup! Now, that would be sweet.
2001 Silverado bagged on 22's. *Sold* |
02-06-2004, 05:39 AM | #31 | |
Thread Tools | |
Display Modes | |
