Old 03-10-2004, 02:44 AM   #26
Razor454
Razor454's Avatar
Ok, this looks like it might be fun.
The age old question everyone vs. Qjet.
I say the same thing about Qjets, they are junk, but they are only junk for one reason, they leak like a sieve. I have two Qjets and two edelbrocks, the Qjets eat them alive on the street when they are properly tuned, but about every six months or so I have to replace the seals to keep them from leaking gas all over my manifold. As for the edelbrocks they are great for someone who doesn’t want to mess with tuning all the time, have never needed to tune the edelbrocks I have (except when I first put them on). Its up to you if you like the stock look, you also might want to take a look at Demon carbs, they seem to be very nice carbs.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi
1997 C2500 Ext Cab 5.7 Liter
1955 3/4 ton 1st series w/ 235 straight six Sold it
Razor454 is offline   Reply With Quote
Old 03-10-2004, 03:09 AM   #27
jimfulco
My '72 350 Qjet has always worked great, & has never leaked, although it did get rebuilt & rebushed after 100,000mi. or so. If it's the original carb that GM put on the truck, keep it, as it's calibrated especially for your engine. A mild cam swap shouldn't give it any trouble. It probably just needs a minor adjustment.
jimfulco is offline   Reply With Quote
Old 03-10-2004, 09:26 AM   #28
CPNE
Resident Curmudgeon
CPNE's Avatar
Pics for Dave
Here you go. If you go with the Edelbrock, the air cleaner spacer and breather tube to RH valve cover must go. Or at least I couldn't make it work properly.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-10-2004, 09:27 AM   #29
CPNE
Resident Curmudgeon
CPNE's Avatar
pic 2
Old 03-10-2004, 09:28 AM   #30
CPNE
Resident Curmudgeon
CPNE's Avatar
pic 3
Old 03-10-2004, 09:39 AM   #31
Dean
Dean's Avatar
I got my carb spacer and hose to the valve cover installed. Maybe I got lucky, but it seemed to fit with no issues. Did you have the original valve covers with the hole in the correct location?
Dean is offline   Reply With Quote
Old 03-10-2004, 11:11 AM   #32
CPNE
Resident Curmudgeon
CPNE's Avatar
I've not had a problem with this on a smallblock. Maybe I did not have correct spacer or didn't try had enough on this BB.
Old 03-10-2004, 07:33 PM   #33
72skytop
72skytop's Avatar
Stock.
Kevin Korff
Evansville, IN 47711
1997 Silverado 3500 LWB Vortec 454, headers 4.11 posi. Victory Red WOW!
1976 Oldsmobile 98 Regency four door 42,000 miles original paint. This is still a car!
1990 Oldsmobile 98 Touring Sedan 34,000 miles
1983 Hurst/Olds 30,000 actual miles
2013 Ford Taurus SHO
1972 Hurst/Olds-a work with no progress
1972 Oldsmobile 442 Convertible 455
72skytop is offline   Reply With Quote
Old 03-10-2004, 07:43 PM   #34
dinnut
dinnut's Avatar
aftermarket. jet performance makes aftermarket quadrajets that are really nice. edelbrock also makes their own version... i just bought a holley 4160 but havent put it on
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 03-10-2004, 09:54 PM   #35
1972C10
1972C10's Avatar
All carbs are junk in the wrong hands Ive owned holleys edelbrocks q jets autolites you name it They all had some quirks but they can be good carbs with proper tuning /jetting
On the edlebrock and gas milage i agree that a q jet will do better
I own a 1985 3/4 ton with 3.73s and Th400 and a stock/mild 355 torque engine.
I took my q jet off to jet it down and had some problems with the jets i used so i stuck an edelbrock on there and had it on there a few weeks I went from 12-14 to 9-11 MPG And it was just a 600 cfm Stock jetting
I finally got the proper jets for my Q-Jet put it back on now im getting close to 12-16 MPG
To mount an edelbrock on a stock intake you need a spacer and for the throttle linkage the stock one will work but you wont have WOT I suggest those Russel Adjustable brackets Or the Sepctre bracket I have installed a ton of these on peoples cars and my own They work good and can be bought with or without provisions for Detent.
1972C10 is offline   Reply With Quote
Old 03-11-2004, 09:06 PM   #36
69 air cab
Thanks you 1972C10........real men like Q-jets
69 air cab is offline   Reply With Quote
Old 03-12-2004, 04:23 PM   #37
1972C10
1972C10's Avatar
Yeah Q jets are ok I like them all I ran an edelbrock on my 72 for a long time i have recently upgraded to a holley DP 750 and i love it over a edelbrock all personal preference
Old 03-13-2004, 12:20 AM   #38
Daves72'GMC
Smile
Thank you everyone and thankyou CPNE for the pics I sure appreciate everyones help. Now to decide.
Daves72'GMC is offline   Reply With Quote
Old 03-13-2004, 02:20 AM   #39
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Edelbrock makes about every bracket you ever need for about every application. Check out their website or your local NAPA store and ask to see their Edelbrock book. Dean has a clean setup!! His engine compartment looks AWESOME
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Thread Tools
Display Modes
