04-08-2004, 01:31 AM | #26 |
5-7 dropped 87 CC Dually
Richin that carb up if you can intill you get pipes. What do your plugs look like? White, tan, brown or black? Try to get it brown to black intill you get some exhust.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
04-08-2004, 01:34 AM | #27 |
Garage Queen Material
they were very dark tan last i checked
04-08-2004, 01:34 AM | #28 | |
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
04-08-2004, 01:37 AM | #29 |
Very dark tan is good.
04-08-2004, 01:38 AM | #30 | |
04-08-2004, 02:10 AM | #31 |
Your dist. set up all wrong form the factory( two heavy silver springs and a red bushing=28 degrees all in at 4000) I just checked out msd website. Change springs to 1 silver(lt) and 1 blue(lt) And change the Bushing to a silver one. This will give you 25 degrees total in the dist all in by 3000rpms. Set timing on the balencer at 11 degrees for a total of 36.
04-08-2004, 08:37 AM | #32 |
i set it the night i got it
04-08-2004, 08:55 AM | #33 | |
how would i wire it up after that? |
04-08-2004, 04:00 PM | #34 |
Heavy wire (10 Ga at least) to battery, through a fuse, to the switched contacts on the relay. Another heavy wire from the other switched contact of the relay to the fan(s). Run a small wire (18 Ga is fine) from a ignition source on the fuse box to your fan switch (or temp switch) then from the switch to the switching contacts on the relayrelay (again 18 Ga). Take another wire from the other switching contacts on the relay and ground it. When the ignition is on, you have power to the switch/relay so it can close (when you choose (switch) or when it needs to (temp switch)). When energized the contacts will close and turn on the fans. When you turn off the ignition the relay opens preventing back voltage from keeping the MSD box turned on. You may also want to put a clamping diode across the switching leads of the relay (if it is not done internally) to prevent any large voltage spikes from being sent back to the ignition terminal.
04-08-2004, 05:55 PM | #35 | |
driving is in my blood
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
04-08-2004, 06:22 PM | #36 |
okay, i got it to idle pretty good i think. but i tried to rev it up a little(maybe 3grand) and when i let off, it wanted to die unless i kept my foot on the gas a little
Thread Tools | |
Display Modes | |
