#476 |
Re: Senior Project Build
to get the crank pulley off, you use the puller on the tabs near the center of the hub, not the outside of the pulley (you'll damage the lip if you pull on the outside).
A pulley puller from Autozone will work for this.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 01-28-2009 at 02:36 PM. |
#477 |
Oh than I better go with 5 inch holes lol.
#478 |
Ok, thanks for the heads up. On the puller I tried, the middle bolt that pushed into the middle was too small, do I need one with a little "foot" to keep it from going inside the crank snout
#479 |
So tonight I cut up some old 2x4s I scrounged out of the back 40 and made a couple of wooden boxes to set the tires on. I like these alot, I holds it up much higher and feels sturdier than jack stands. Am I the only one who cuts lumber with a sawzall? lol
![]() ![]() ![]() ![]() Now I need to make a set for the front! I got a box full of junkyard parts today, a starter, alternator, and a power steering pump. Man these starters are small and light weight. I hope it all works. Good old U pick it stuff. I should be making a trip to harbor freight this weekend, maybe friday so I can score a puller and some other crap. ![]() ![]() ![]() And I got some Bondo supplies today. I just need to get a bigger grinding wheel and clean out the spot some more. ![]() ![]() |
#480 |
Here are a couple very horribly blurry pictures of the rust
![]() ![]() Im going over to my friends house in a few minutes to borrow some POR-15, so after I grind it up I can slather it in rust inhibitor, then spread the mud. One last shot of my bed full of parts waiting to be installed. ![]() |
#481 |
Good choice to go with tthe POR 15 first IMO. It is some bad stuff..hope you wore gloves! I got it on me doing a underside of a Charger and damn near had to use a belt sander to get it off my arm..
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#482 |
No sir...you aren't the only one.
Being a deck builder means the sawzall is my friend! I cut wood all the time with it. In fact at one time I had four of them! Of course when it counts I cut on the sliding miter saw or by circ saw, but sometimes they aren't within reach! Nice blocks. I need to make some more of those. I also made ramps once outta 2x4's back in the 70's when I was a young-un. Didn't have the cash to buy the metal ones.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
#483 |
Leave the crank bolt in the end of the crank, back it out about 1" and let the puller bolt tighten against the head. When you get the pulley moved out tight against the bolt, then back the bolt out some more. The bolt threads in there pretty deep. With the pulley backed out 1-2" it should come the rest of the way just pulling on it w/ you hands or tapping with a mallet.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
#484 |
Ah of course! Leave the crank bolt in! Thats a great idea. Thanks! And Im glad Im not the only one who uses the sawzall to cut everything around the garage- but your right, if you want precision it is not the way to go! I didn't get the POR-15 last night, my buddy I was going to borrow it from works the late shift and wasn't going to be home till like 1 am so I said screw it I'm going to bed
#485 |
Picked up an ACC 10'' Torque Converter today, 3200 stall speed. Brand new in the box.
![]() ![]() ![]() And a box of stereo stuff showed up today ![]() ![]() ![]() I bought a bigger grinding wheel and ground out some of the rust tonight, the holes got bigger ![]() |
#486 |
I cruised over to Zigs Hot Rods and picked up a Hagan gas cap, with the spring loaded flap in the middle. They only wanted 23 bucks for it, online it was like 25 plus shipping. I felt good that I could actually buy something locally. They have a ton of sweet billet stuff to drool on a lots of cool projects out back. Now all I have to do is pirate the filler neck of a late model GM and mate it to my fuel cell.
#487 |
This evening I got the balancer off, (after I broke a harbor freight puller) dropped the pan, pulled the oil pump, cam sensor, cam cover, and the timing gear and chain. Then slid out the stock cam. Is a stock LQ4 cam with 100k on it worth anything?
![]() ![]() And I went junkyard crawling (I ditched school ![]() ![]() ![]() ![]() Last edited by LuckyHenriksen; 02-03-2009 at 01:32 AM. |
#488 |
I have a marine cap I got from Boat World...I like it but it's a pita to open with the key so I use a screwdriver.
#489 |
Hmmm thanks for the heads up. About how much did it cost?
#490 |
I have a new valve on order from sdparts and they are taking forever to get it out, along with new gaskets and timing chain. I can't wait, as soon as I get all the stuff back I can start reassembling the motor. There is plenty to do in the meantime, like relocating the fuel cell to under the bed, reinstalling the interior and adding 5 point harnesses, setting up extra gauges, etc. I will update here when some progress is made
#491 |
I got home from an exciting weekend riding and found parts!
The new intake valve for the L92, the damn thing is almost as big as my VW key! I can't wait to get the heads back together ![]() ![]() And .49 Cometic head gaskets....... supposed to give me like 10.6:1 or something close to that. ![]() And a bunch of other gaskets, seals, new crank bolt, MSD Super Conductors, etc. ![]() And a new double roller timing chain! ![]() Tomorrow I have the day off school, so I can get the parts to the machine shop, start assembling the bottom end of the motor, and work on getting the interior and fuel system together. Now I just need head and intake bolts! |
#492 |
Damn...you sure that's not a cymbal? Huge valve!!
#493 |
Lol thats what I said when I unwrapped it
#494 |
Eat My Rust
This ain't know honderr
#495 |
Hell ya it aint
#496 |
Here is a random picture of me this weekend
![]() Girlie on the back ;D ![]() |
#497 |
Grandpa in the rustmobile...
uh oh luckys gotta woman!!...
nice...?raptor? and snow! thats more than we get down here
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#498 |
72 chevys 4 life
did you ever get the specs on those wheels? those tires fit out back good didnt they? or did you have to modify a lil?
I dont call it being young and dumb....I call it young and havin fun ![]() |
#499 | |
![]() The bike is a YZF450, and I think it needs a 589 stroker kit soon ![]() |
#500 | |
Front Tires: 195/65/15 (I wish I had gotten a taller sidewall) Rear Wheels: 15x10 4.00 BS Rear Tires: 28x13.5 ET Streets They all fit together nicely, but I would go with an inch or so narrower on the rear tire, unless you narrow the rear end you can't lower it enough to tuck into the fender. This would also require tubbing out the bed. This may be in my future as I want to be able to tuck it up inside. I got the ET''s because they were brand new and cheap off craigslist ![]() |
Thread Tools | |
Display Modes | |
