#476 |
Re: 1991 V3500 Project Heavy Hauler
Thanks. It's about 2" wide and 3/4-7/8" deep. I used a stepped drill bit to open up the hole enough to go over the steering wheel splines without being too big to use the steering wheel nut without a washer. Hope that helps.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#477 |
Looks like you had a fun trip, and now looks like you are going to have a fun time installing headers. Big block + headers = mo pawa!!!!
#478 |
Maybe I missed it, but...
What kind of fuel mileage are you getting? I just bought a 1991 with a TBI 454
#479 |
Thanks Dave. Headers or a lot of fun to install! Hey Joe did you buy that one for $2500 with a busted column and dented fender off CL??? I was salivating. Last trip was a little better than 11 mpg not driving gently. There is room for improvement. I'm getting it tuned the first week of August. Still sets an occasional SES light for too rich.
#480 | |
That's the one I got. It's gonna be delivered to my house Thursday. I can't wait! That's cool Who is doing your tuning?
#481 |
Awesome, that looks like a solid rig. What are your plans for it?
Tuner is a guy named Richard Wayne. A bunch of hot rodders here are bringing him up to tune their exotic rigs. LS motors with power adders... Mine will be easy and boring, but hopefully improves the performance and stops setting SES lights for rich condition. Mine is modified enough with the cam, headers, bigger injectors that it would benefit. I compared the "hot" howell tune to the stock one and they are identical save 2 degrees more timing at upper RPM, so I think there is some room for improvement.
#482 |
I just want to clean it up and fix all the issues to make it a nice driver, maybe see if I can up the power a bit.
Cool deal on the tuner guy!
#483 |
Time to see how yet another company's customer service is. These are the gaskets that came with the Thorley headers.
#484 |
Oh nice!
I didn't know you had the big block V-10 ![]() ![]()
#485 |
cut to fit prolly
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#486 |
Ford 6.8 V10 actually by the part number on the packaging. Hopefully they express mail me the right ones... Put the headers on with the old gaskets which were in good shape.
Drivers side came up through the bottom, passenger side through the top. As tight a fit as any headers I've installed. Had to move fuel lines, trans cooler lines, batter cable and knock sensor wire but fit seems good.
#487 |
Hell ya man! Moving some stuff is a small price to pay for mopawa!
#488 |
Made the deadline, got the headers on and she is tuned. Pretty noticeable difference. Fuel map corrected, timing added, shift points adjusted, idle smoothed out and probably a few other things I'm forgetting. Guy knocked it out in a little over an hour of driving and stopping. I'll do a video once I get the exhaust fixed (flex pipe) and have some time. Even with all the weight in the back she smokes the tires from a standstill by mashing the gas.
PS Thorley came through with the right gaskets in time to only do that once. Yay customer service!
#489 |
Had a couple plug wires pulled off on the drivers side. Top side on drivers was a PITA, bottom side on the passengers was a PITA.
#490 |
Awesome!
Those headers look very nice!!
#491 |
Glad to hear that everything worked out.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
#492 |
Awesome truck. Pretty much what I am working on doing with my 73 c20. I just plan on going to a ls in the next year or two. What GPS/tracker do you use?
#493 |
The amount of work you have done on your truck is amazing. I also have a 1991 V3500 myself. I have done a decent amount of work on my truck as well...things such as fuel tanks (pumps), engine, transmissions, rewiring, and steering components. My list makes it all sound easier than it is, but you have a first hand understanding of what I am talking about.
#494 |
6>8 Plugless........
![]() Join Date: Sep 2007
Marcus, those headers are very nice! That is a pretty nice fit too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#495 |
Dang it. This is now making me contemplate keeping my big block instead of doing a Cummins swap. What MPG do you get if your not hammer down?
68 C10 lwb, 406 sbc, 700R4 86 K30 srw, 454 bbc, TH400 11 Camaro RS, 217 V6, 6M |
#496 |
Thanks guys, appreciate all the compliments. Nice looking truck, 1-ton. Do you have a build thread going?
iPad app is Hema USA. I use a different one called copilot for turn by turn instructions. Both work pretty well for what they are. Hema allows you to load all kinds of different quadrangle charts, road maps or nautical charts and shows your position on them. I haven't run any more full tanks through it since my big trip, so no more MPG reports, but will post them when I do. A few points to consider with my fuel mileage: I'm running multi point fuel injection, have an overdrive trans and a lockup torque converter. But I also ha e 4.56 gears and I'm sure would do better with 4.10's or 3.73's. My main reasons for disliking diesel is they are loud, stinky and suck in the winter when it is below zero. Currently working on installing a new tie rod and drag link, then I need to get to the exhaust shop and get my flex pipe replaced with something permanent.
#497 |
Anybody have a recommendation on a steering damper? Mine is hammered. Bilstein doesn't list one for our application, which is too bad.
#499 | |
brian.mccroskey@thyssenkrupp.com If not, then you may be able to get a napa or monroe shock replacement for your current one.
#500 |
Thanks for the pointers guys. Was actually able to get a made in the USA replacement from Napa. Inter web said my store didn't have one but the parts guy made some magic happen and it bolted right in.
Tie Rod went in easily. Drag link is being a PITA. It almost looks like it has a cone washer. Anybody know a trick? Factory service manual is less than helpful. Get a big hammer and hit it with a little hammer...
Thread Tools | |
Display Modes | |
