Old 05-18-2013, 01:18 PM   #501
_Ogre
_Ogre's Avatar
Re: 51 Chevy 1/2 ton, My S10 swap
wow, looks good atommik
shop air compressor timer
Old 05-18-2013, 03:35 PM   #502
mknittle
mknittle's Avatar
if you use the temp sensor in the head it will read hotter than on the intake. It isn't bad as long as you know.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-18-2013, 04:17 PM   #503
Daze57
Daze57's Avatar
Isn't that a more accurate reading if the sensor is in the head?
Daze57 is offline   Reply With Quote
Old 05-18-2013, 04:19 PM   #504
Daze57
Daze57's Avatar
Atommic
Looks great!
Old 05-18-2013, 04:20 PM   #505
Daze57
Daze57's Avatar
Old 05-18-2013, 04:23 PM   #506
Daze57
Daze57's Avatar
Temp Sensor More accurate in the head isn't it ?
Old 05-18-2013, 08:04 PM   #507
Atommik
Atommik's Avatar
I'll be using the original location for the temp sender, on drivers side right by the headers, and the same on the pass side for the fan switch.
Installed the electric fuel pump today, runs 4-6 psi. Didn't think it was picture worthy. Also finished shortening the drive shaft. I installed it for now but it will need balancing before I drive more than across the street!!
Finished the battery hold down. I was just getting ready to run the spark plug wires, but on further inspection of them...they are junk. Back to the parts store!!
Started on the gauges...I swapped the original fuel gauge for a new aftermarket GM one and transferred it to the original face plate in the cluster. I like how it turned out except the needle is not as long, but I can still read it. Put on new faces on the gauges. Speedo next!
Atommik is offline   Reply With Quote
Old 05-18-2013, 08:33 PM   #508
Daze57
Daze57's Avatar
looks really nice
sorry for all the posts - stupid pc
Old 05-19-2013, 12:38 AM   #509
mknittle
mknittle's Avatar
Not really because it is close to the heat of the combustion chambers where the water temperature is higher than in the rest of the engine. I like to put the sensor in the crossover close to the thermostat. That way I feel that I can tell if the thermostat is working like it should.
Mark
My GMC build.
Old 05-19-2013, 12:39 AM   #510
mknittle
mknittle's Avatar
looks really nice
I am glad I am not the only one that has that problem from time to time
Mark
My GMC build.
Old 05-19-2013, 12:43 AM   #511
mknittle
mknittle's Avatar
looks good to me. I didn't notice the needle until I read your post .
Mark
My GMC build.
Old 05-22-2013, 08:23 PM   #512
missinfishin10
Amazed Member
missinfishin10's Avatar
Awesome build, just read front to back... wanting more, more!
Fire it up!
71 LWB Fleetside
1950 3100 Original Project!
missinfishin10 is offline   Reply With Quote
Old 05-22-2013, 10:10 PM   #513
Atommik
Atommik's Avatar
Just picked up the correct style plug wires and a fuel line and in line filter and a few other misc. parts. I hope to have more time this long weekend to make some good progress.
Old 05-23-2013, 11:53 AM   #514
skymangs
skymangs's Avatar
Looking great Atommik, getting real close to done.
x2 on the temp sensor being right next to the water neck, I put mine there as well.
skymangs is offline   Reply With Quote
Old 05-23-2013, 12:22 PM   #515
54 jimmy
54 jimmy's Avatar
that's where I put mine and it works fine.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 05-25-2013, 10:07 PM   #516
Atommik
Atommik's Avatar
So...big day today.
Started out finishing up the fuel line connections.
I got the horns installed (salvaged from a wrecked BMW).
Fit up the radiator and trimmed up the support to get it in place. I still need to make the top support brackets. Ordered rad hoses and fittings for the temp sender and fan switch. On a side note, I wish there was a good old fashioned "speed shop" around here. The local parts stores are good for some things but when you need something simple like npt fittings or a simple sbc temp switch...no luck.
Lastly, I fired up the engine today!! It started pretty well after I remembered to turn on the switch for the elec. fuel pump. No coolant in it so I only ran it for about 10-15 seconds. It's just running thru the headers so it's a little loud, and I have now tightened the headers bolts the rest of the way to stop the exhaust leak you will see in the video. I am so excited to get to this point on my project!!
Old 05-25-2013, 10:32 PM   #517
99 to Life
99 to Life's Avatar
congrats man, getting so close I bet your just drooling over it. Been there and I'm sure we all have been. The first test drive one of the biggest reliefs ever. Getting it inspected is another, then ironing out the kinks is another, then after a while you'll find things you want to change, then have to fix, ahhhh the list goes on, a project is never really done cause its always gonna be a project!! Is it me or am I the only one missing the video??
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-25-2013, 10:43 PM   #518
Atommik
Atommik's Avatar
It's taking a while for me to figure out the video down load. Thanks to my daughter, here's the link: http://www.youtube.com/watch?v=mf9fe...ature=youtu.be
Old 05-26-2013, 12:21 AM   #519
oldman3
oldman3's Avatar
Congrats, sounds good...Jim
oldman3 is offline   Reply With Quote
Old 05-26-2013, 10:22 PM   #520
N.T.Q
sounds great, it was fun watching your build great job
N.T.Q is offline   Reply With Quote
Old 05-27-2013, 07:08 PM   #521
Atommik
Atommik's Avatar
Thanks for the compliments guys!!
Spent a little time Monday morning on the truck. I finished modifying the alternator and power steering brackets. I painted the rad support and made the upper and lower mounts for the radiator.
I was having a hard time deciding what to do with the air cleaner cover. I decided the blue color just didn't fit with the rest of the truck, so I two-toned it to match the two-tone on the grill. Came out nice! plan to have a little pin srtiping done to the air cleaner also
Old 05-27-2013, 07:49 PM   #522
99 to Life
99 to Life's Avatar
looks good
Old 05-27-2013, 11:24 PM   #523
oldman3
oldman3's Avatar
Nice...Jim
Old 05-28-2013, 08:55 AM   #524
mknittle
mknittle's Avatar
Looks real nice. If I went with a v8 I would use one of those air cleaners. the two tone came out real nice looking!
Mark
My GMC build.
Old 05-30-2013, 11:49 PM   #525
Atommik
Atommik's Avatar
Just got back from getting some exhaust tubing, hangers and a muffler. I think that will be Saturday's project. I found some rad. hoses I was able to use after a little trimming. Hoping to install the heater tomorrow at lunchtime so I can fill the coolant and let the truck run a little.
Thread Tools
Display Modes
