06-14-2017, 11:02 PM | #5451 |
Re: What did you do to your truck today? Chapter II
Went for my first road test since my frame off.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
06-14-2017, 11:04 PM | #5452 |
Sooo how was the 1st run in the truck, bet it was nice to get out in it again.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
06-14-2017, 11:42 PM | #5453 | |
I upgraded so many systems. The power steering was great. The disk brakes acted as they should. The lowered height, with Bilsteins and sway bars made it handle really well. The full syncro trans (still on the column) was nice to use. The 2:76 rear end was such an improvement over the 4:11s that were in it. Although it kicked my butt twice, the Centerforce clutch works perfect. Last but not least, the 396 runs really well. I fried the tires a couple of times. It has a lot of power. I've got a ways to go still.
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod Last edited by ghalperin; 06-14-2017 at 11:51 PM. |
06-15-2017, 01:05 AM | #5454 |
Yesterday I got my original 4 row (lower) radiator brackets sand blasted. A friend from jr. high I haven't seen since 1998 did that for me at this shop. Great seeing him again and getting that done.
06-15-2017, 02:51 PM | #5455 |
Replaced the old "3 Wire" Alternator with a new "1 Wire" Alternator.
Quick and painless.... |
06-15-2017, 07:20 PM | #5456 |
laying low
[QUOTE=ghalperin;7967753]Went for my first road test since my frame off.
Attachment 1661379 As my friend says "that's cool beans right there". Good looking driver. Your truck makes me wish I still had the 3ott in mine.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
06-15-2017, 11:19 PM | #5457 |
Broke a fan belt on my way back from the hardware store. Had my wife pick me up, quick trip to the auto store, 15 mins to put on a new belt. Gotta love working with old trucks.
'72 Highlander '88 GMC Sierra 1500 '14 Chevy Silverado 2500HD Duramax |
06-15-2017, 11:24 PM | #5458 |
Your sure right on the belt and old classics, try that on any new vehicle, lucky to see where the belt even goes.
Mudman.
06-16-2017, 01:13 AM | #5459 |
I installed two valve cover gaskets, a fuel pump and some new fuel hoses and an inline filter,
I got rust in the tank problems. Discovered a vaccuum line leak between the carb and the vaccuum advance. |
06-16-2017, 02:04 AM | #5460 |
I got a little something done yesterday (posting at 2 AM). I put NAPA Rust Treatment onto my lower radiator brackets as a primer.
06-16-2017, 10:02 AM | #5461 |
I'm no mechanic but I really do enjoy puttering around and fixing things up. I love how easy these trucks are to work on and I really enjoy all the help I've received on this site.
06-16-2017, 01:59 PM | #5462 |
I did the same when I restored my '71, found out the original wiring could not carry the robust charging capability of the one-wire alternator. The factory fuse link or if you replace it with an inline fuse may not handle the potential 60 amps or so that it can generate so I added into the harness a 10 guage wire direct from the alternator to the battery. Great add though for these old trucks even though it knocks out the generator guage function. May deal with a voltage guage in it's place at a later date.
06-16-2017, 09:05 PM | #5463 |
Picked up my freshly upholstered buddy seat , dug out tach dash . Now to install tilt column & power steering . Soon !
06-17-2017, 01:57 PM | #5464 |
I went to Donut Derelect's and then Home Depot.
06-17-2017, 04:30 PM | #5465 |
06-17-2017, 10:39 PM | #5466 |
Picked up the wheels from powder coat and got the tires mounted.
15x6 225/70/15 BFG Radial T/A 15x8 275/60/15 Nitto 555r
You remember when drinking too many beers was a bad idea? Me neither. |
06-17-2017, 10:51 PM | #5467 |
I brought my truck home ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
06-18-2017, 02:55 AM | #5468 |
gave my front end a lube job
noticed that my disc brake pads need replacing tommarrow i'm going to flush my cooling system |
06-18-2017, 04:18 AM | #5469 |
Yesterday I got my 4 row lower radiator brackets painted. That should do it for front-end reassembly preparations.
06-18-2017, 12:24 PM | #5470 |
I added a tailgate lock.
06-18-2017, 08:14 PM | #5471 |
[QUOTE=ghalperin;7969613]I went to Donut Derelect's
Left LA in January, miss that get together. Awsome looking tuck! Went to pick up some yummy southern barbeque for fathers day. But usually run into this traffic on the weekend in the middle of the day. Joys and pain of living on the beach, but who is complaining, I moved here from LA. This is nothing. Did a little work Saturday on the roof surface rust repair. Also went to a car show but just saw a bunch of new mustangs and corvettes. Not much of a show, passed a bunch of those on the way there. Lol Happy Fathers Day all! |
06-18-2017, 10:09 PM | #5472 |
Took the bed back off the frame and took it apart and put the new sides on and sat it back on the frame today. Will finish mocking it all up tomorrow...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
06-19-2017, 12:07 AM | #5473 |
Got into the front end today, man if you do not have an oxy torch its a pain. I torched off those upper ball joints in less than 5 min. flat. Then onto the stuck lower ball joint. Red hot on the ball joint stud then hit with the hose, 3 times over. Ball joint removal tool and a punch it fell right out.
Having the right stuff is a blessing. |
06-19-2017, 12:08 AM | #5474 |
I put my front bumper and inner fender wells back on.
06-19-2017, 02:45 PM | #5475 |
Finished the ignition portion of my maintenance binge. Pulled the distributor, replaced the points, condenser, cap and rotor (plugs, wires and coil were replaced a few weekends ago).
As much as I love the SBC, there are times when I think Ford had the right idea. Full-size truck with a 4" lift, getting to the distributor is a real chore as an older fat guy. Turned a two hour job into several hours across two days. Adjusted timing and dwell, the beast purrs like a happy beast now.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
Thread Tools | |
Display Modes | |
