#576 | |
![]() Join Date: Jun 2009
Re: My 68 swb build.
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
#577 |
Anyone? I'm not a body guy by any means.
#578 |
I find points that are identical on passenger side and drivers side such as mounting bolt holes for fender etc. I measure from driver side cab hole to passenger front frame horn. then i do passenger side cab hole to drivers side frame horn. Then I adjust til i am within an 1/8 inch. Then i do the same on the back of the cab side to side and diagonally until it sits square. Sounds like overkill but it has solved alignment issues before.
#579 | |
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 Last edited by 77chris03; 11-08-2011 at 11:40 PM. |
#580 |
VA72C10
![]() Join Date: Mar 2008
Check what he mentioned....thought the core support might be the issue and it looks more like it with those recent pictures...
also, on the hinges, how are you adjusting those. I have found I loosen all the bolts on the fenders and push as far up as I can...then have someone tighten the hinge to fender bolts while I hold it there....that helps some too....and make sure they are even on how far they are in relation to the distance from the back of the cab to the back of the hinge. This is the reason you're supposed to 100% mock up everything before paint ![]() ![]() looking good though! Starting to resemble a truck...and a cool one at that! ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#581 | |
#582 |
im lost....i cant get it straight...and im getting pissed off cause i put another chip in the fender....
#583 |
I wish I could be of more help to you, but I couldn't begin to tell you where to start. I hate that you are having so much trouble with the alignment. Sometimes its best just to walk away and get a beer>
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
#584 |
Hang in there, You'll get it. I agree, grab a beer and walk away for a bit.
1972 GMC (PROJECT LONG OVERDUE) ![]() 1998 SWB 4WD |
#585 |
One of the problems.... Drivers hinge bad. Bought new ones this morning and almost got it perfect. Still have issues with door to fender and I think i have to redo the doors too.
#586 |
It sucks. I have had the same thing happen. I learned from my mistakes and now I always mock up my doors and front clip before paint. I even drill pilot holes in the panel by the bolt hole so i can get clip right where I had it during mock up.
#587 | |
ya but my problem was i didnt have the parts readily handy and the body guy didnt wanna do it....
#588 |
Chris, your truck is looking really good........ i trust you will get the alignment thing handled.... it may challenge your patience... but u will get it.
#589 | |
#590 |
heres a little update...not perfect and it kills me that its not.. oh well ill try to get it closer if i can. maybe post some pics on this thread of body lines for reference?
#591 |
VA72C10
Looks good man! I don't think you'll get it any better...these trucks had avg to poor quality control when it came for panel fit and alignment from the factory...
The only way to get it better is to mock it all up first and shave down or add material to the panels to make perfect gaps. At this point....I think you need to step away and move on...I know you're frustrated with it... ![]() ![]()
#592 |
got these put in too...why not...lol got prebent brake lines from outback sat morning...so much easier..lol
#593 |
i am so confused on this part of the brake line setup with what came with the line kit... Finally got one of these too.... Does this look like it will work??? i cant find another hose to work..
#594 |
if it wont ru on anything or touch anything hot then i would say you should be fine.
#595 |
#596 | |
#597 | |
#598 |
Looking good! You're making nice progress. Don't forget to post a video so we can hear it run.
#599 |
how do i upload videos?
#600 |
haha i fingered it out... this was saturday morning... this is the first fire up since it was test fired after i built it...hopefully she will run like a cheetah...
Thread Tools | |
Display Modes | |
