Old 08-18-2011, 08:44 AM   #601
Pick
Pick's Avatar
Re: Project Lemon Drop: anything but stock!
Originally Posted by belowme51 View Post
fastbagged idea is perfect. i think the louvers would allow hot air to go into the box then your just not allowing the hot air to escape.
You have to get cool air in and hot air out in order to cool it effectively...as a general rule, air won't go in if it can't get out. It's the air passing through that actually does the bulk of the cooling. Louvers facing the airstream on one side and facing the opposite direction on the other side (or top) should work........anything to allow air to pass through and not stagnate inside.
Pick is offline   Reply With Quote
Old 08-18-2011, 09:08 AM   #602
kikkegek
kikkegek's Avatar
I am very curious about your door panels. lookin good!
kikkegek is offline   Reply With Quote
Old 08-19-2011, 07:22 PM   #603
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
looking good dude ,i went by the shop and notice chevy trucks were gone lol
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-19-2011, 07:25 PM   #604
64shortc10
64shortc10's Avatar
Beautiful truck. Keep it going!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 08-19-2011, 08:33 PM   #605
jugernot
Life, Be In It.....
jugernot's Avatar
Yeah it was looking like a 67-72 chevy truck depot for a while.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 08-19-2011, 08:34 PM   #606
jugernot
Life, Be In It.....
jugernot's Avatar
Tony from Norcal
Thanks, Just trying to make you neighbor (Kevin) proud.
Old 08-20-2011, 10:33 PM   #607
jugernot
Life, Be In It.....
jugernot's Avatar
Some good news. Someone beside me has a hansome face now! I put the trim rings on the headlights and grill. Putting the clips into the grill trim pieces took a bit of time, as did putting the nuts on the dash pad. It turned out nice. I noticed that there are some hole on the front bottom side of the dash pad, but there was no hardware. Anyone know if screws or bolts go into these hole?
Bad news, I tried to start the truck today and well nothing. Not even a click from the starter. I did hear a click coming from the Accuair relay and the Accuair control pad was flashing. At one point the arrows on the control pad were red. I'm not sure what all that means. I haven't had a chance to check the manuel. I thought that maybe the battery was low and tried to jump it, but still nothing. I hope it is nothing big.
Old 08-20-2011, 11:14 PM   #608
VA72C10
VA72C10
VA72C10's Avatar
Looks good. Definitely sounds battery related...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-20-2011, 11:47 PM   #609
jugernot
Life, Be In It.....
jugernot's Avatar
I think my power steering box is leaking. I noticed a couple of small puddles on the ground below it. It felt and tasted like power steering fluild. If I have to replace it I think I would get one of the Early Classic ones that have a tighter turning ratio.
Old 08-21-2011, 12:18 AM   #610
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
looks great, hopefully it's minor, sounds minor
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 08-21-2011, 10:13 PM   #611
jugernot
Life, Be In It.....
jugernot's Avatar
Today I made a mock up of my speaker pods and door panels to help me decide how I want them to look. The area next to the speaker pod will be a map pocket. Im still trying to figure out how the arm rest is going to work.
The drawing looked good on paper, but I wasnt sure how it will look until I made a 3D version. I like it so far, but I still have somethings to figure out before I throw some fiberglass down.
Old 08-21-2011, 10:33 PM   #612
VA72C10
VA72C10
VA72C10's Avatar
I love the look of speaker area but honestly think (while very functional) the map pocket will date the panels. When I see map pockets I think conversion or mini vans. Maybe it's just me
Old 08-21-2011, 11:19 PM   #613
VWBeamer
My friends new truck has map pockets.
VWBeamer is offline   Reply With Quote
Old 08-22-2011, 12:21 AM   #614
jugernot
Life, Be In It.....
jugernot's Avatar
A very good point, I will keep it in mind. What else could I use that area of the door for? I think it would look odd if there was nothing in the place of the map pocket.
I originally came up with the map pocket idea because I lost half of the glove box with the vintage air system and just wanted additional cargo area. I was also thinking a making part of the map pocket, a cup holder, but there is just not enough room between the seat and door. I also plan on putting a amp and sub woofer behind the seats. I guess I could include more cargo space there.
The small rectangle panel that appears to be part of the speaker pod is going to be door to the compartment for the electronic cross over.
Old 08-22-2011, 12:50 AM   #615
VA72C10
VA72C10
VA72C10's Avatar
I definitely think it'll be functional and honestly don't have a better idea of a use for that area and do like how it continues that depth of the components to the end of the door....
It's not like it'll be pleated vinyl with buttons so it might turn out looking pretty nice...and as VWBeamer said....most new vehicles have them...
...I'm just not used to seeing them on show trucks which is definitely what your truck is!!!
Old 08-22-2011, 12:59 AM   #616
71Sleeper
71Sleeper's Avatar
Jugernot, I agree with the map pocket. I think just having the speaker pod on the bottom will look more like just a box screwed to the door to accomandate a speaker and would not flow well by itself. Especially if you are installing a longer arm rest the bottom of the door will not look proportioned without the map pocket. Just my thought.
71Sleeper is offline   Reply With Quote
Old 08-22-2011, 01:14 AM   #617
jugernot
Life, Be In It.....
jugernot's Avatar
Thanks for all the input. I have seen the many kick panel speaker pods, but don't care for them. I do not want to move the dimmer switch either. I do plan on making something for the kick panel, but no ideas yet.
The one draw back with the speaker pods on the door is that when the door is open it takes away a good portion of the room for getting in and out of the truck. I will have to be careful with my feet. I don't want to cut into the inner door.
Old 08-22-2011, 02:10 AM   #618
kikkegek
kikkegek's Avatar
looking good. Like your speaker pods.
Old 08-22-2011, 03:08 AM   #619
plummen
Originally Posted by Rokcrln View Post
This is stage one of the fire wall. Stage two will be first part of the week.
Kevin
LFD Inc.
Nice work!I was eyeballing the firewall on my 69 project today while i was stripping the floors,i need to fill a lot of the same holes!
Except the hole for the heater,it gets cold here in nebraska and i plan on driving this one!
plummen is offline   Reply With Quote
Old 08-22-2011, 05:19 PM   #620
jugernot
Life, Be In It.....
jugernot's Avatar
You were right and I'm glad you were right. I took the battery to Napa Auto Parts and they hooked it up to the battery tester and it was only putting out about 4 amps. So they threw it on the charger for a couple of hours, but when I called to check the status, they said the battery was no good. So $105.00 later and Lauren and I went for a quick drive around the neighborhood. I was so happy that it wasn't something more serious. I ordered a "Battery Tender Jr." That I will hook up while the truck is sitting unused in the garage.
Old 08-22-2011, 10:08 PM   #621
jugernot
Life, Be In It.....
jugernot's Avatar
I was just going through some pictures from when I first bought the truck. So I thought that I would share a BEFORE and AFTER pictures.
When I originally bought the truck it had a narrowed rear from with some really fat tires. After I purchased the truck I learned that the back half of the frame build was done incorrectly. So I had it redone, by what I thought was a reputable hot rod shop in Sacramento, but months later found out that one of the frame rails was welded on crooked. So realized it was best to go with a complete original frame.
Old 08-23-2011, 12:54 AM   #622
mcmlxix
Collector of Projects
mcmlxix's Avatar
Try these guys... I got a box from them for my K5...
http://www.redheadsteeringgears.com/
Rich
1972 K5 Blazer CST Click HERE
Old 08-23-2011, 08:11 PM   #623
jugernot
Life, Be In It.....
jugernot's Avatar
I took a break from the door panels and installed the carpet. I hope it will cut back on some of the heat from the exhaust. I started to put the seats back in, starting with the center seat, But found the went the center seat/console was in the up position it rubbed against the rear of the cab. I have to do some trimming and drilling on the base of the center seat.
Old 08-23-2011, 11:38 PM   #624
plummen
Keving Its looking great. Glad I could help with the up coming THING as well. I am looking forward to seeing both of them complete. I am off from work next Sunday, if you need any help let me know. I would be great to see the MASTER at work. You don't charge anything to watch do you??????
I just got a bunch of parts back from powder coating. Here are some pics of some of the parts.
I was wondering is there any differance in the pedal assembly/hanger between the auto and 4 speed versions other than the clutch pedal itself hanging on one side?
Old 08-24-2011, 08:30 PM   #625
jugernot
Life, Be In It.....
jugernot's Avatar
I have a question about Jute padding. The carpet kit I bought came with some Jute pad that covers the lower part of the fire wall and goes down to about where your feet rest.
Do I need to spray some adhesive on the Jute to make it stay in place?
If so, should I glue it to the sound deadner on the floor or to the underside of the carpet?
Thread Tools
Display Modes
